Rear cylinder drops - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 9 (permalink) Old 10-29-2018, 07:59 AM Thread Starter
Rear cylinder drops
84 vt700 is what were dealing with. Have a on going issue with the rear cylinder dropping in first gear at the bottom of the gear on take off. Ive adjusted the af screws , no improvement, checked plugs and wires spark is good. All other gears the bike runs great. Yesterday it was do bad the bike would die after 15'-20' of take off. Any advice on where to look and for what ?
Sent from my SM-G950U using Tapatalk
bigolepit is offline
post #2 of 9 (permalink) Old 10-29-2018, 09:34 AM
smilie's Avatar
Have you got a plugged pilot jet on the carb for that cylinder?
smilie is online now
post #3 of 9 (permalink) Old 10-29-2018, 10:52 AM Thread Starter
Not sure. Gonna tear the carbs down Wednesday and check. Good thinking friend
post #4 of 9 (permalink) Old 10-29-2018, 01:35 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
If it idles well on both cylinders in neutral try a couple of simple things first.
Take out the mixture screw for the problem cylinder(don't loose the spring, washer or O ring), and spray some carb cleaner in through the hole.
And if your idle speed is set too slow it can cause a stalling problem taking off from a stop. I found that out my self.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #5 of 9 (permalink) Old 10-31-2018, 09:21 AM Thread Starter
@swifty2014 gusse what i just lost......wait for it,.........the dang washer from the af screw. I think someone pounted out not to loose that piece lol
post #6 of 9 (permalink) Old 10-31-2018, 12:43 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
You can probably run it without the washer for a while, the o ring will seal, but I would order one like this to put it back in proper order.
https://www.ebay.com/itm/HONDA-VF110...2:pf:0&vxp=mtr
https://www.ebay.com/itm/Honda-83-84...5:pf:0&vxp=mtr
1983 750 Shadow
From the past=
post #7 of 9 (permalink) Old 10-31-2018, 12:48 PM Thread Starter
@swifty2014 i made a fast run in the pickup to my local bike shop. He had yhe washers and orings in stock $1.99ea. Grabbed yhe washer and figured put new orings in both carbs since i already had it apart. Was just funny as soon as i dropped it your warning popped in my head lol
post #8 of 9 (permalink) Old 10-31-2018, 12:52 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Good to hear it will be an easy fix !
Hope you get the idle circuit cleaned by that method too. If you put the straw on the carb cleaner can, and put a rag over the opening, you may be able to "back flush" into the jet.
1983 750 Shadow
From the past=
post #9 of 9 (permalink) Old 10-31-2018, 02:40 PM Thread Starter
I have a bucket of chemdip i keep around. Just did a compleat tear down on the carbs and let the parts and jets soak then blew it all with the compressed air. All yhats lefy yo do is resync the carbs lol
