Rear suspension adjustment - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 12-29-2018, 11:21 AM Thread Starter
tjkoko's Avatar
Model: 2015 VT750C Aero
Year: 2015
The rear suspension on my 2015 VT750C Aero is set to "2", "soft" as indicated by my owner's manual. I weigh 230 pounds. So how would I know to reset it to some other number, probably "stiffer"?
I am coming from an older Triumph Tiger background.
tjkoko is offline
post #2 of 12 (permalink) Old 12-29-2018, 11:39 AM
smurfy71's Avatar
The best thing to do is try different settings and decide what you like best. Adjustments to the rear shocks will affect more than just the bumps. It affects cornering. Experiment.
Sitting on my VTX making Vroom Vroom noises.
https://www.hondashadow.net/forum/me...e71386-vtx.jpg
2006 Shadow Aero 750, "Audrey" - Jan 2017 BOTM - Sold Oct 2018
2008 VTX 1300T - Oct 2018 Co-BOTM
smurfy71 is online now
post #3 of 12 (permalink) Old 12-29-2018, 02:05 PM
smilie's Avatar
Like @smurfy71 says, there are trade-offs. Depends a lot on how you ride. At your weight you're probably on the min setting without bottoming out. If you want a softer more cushy ride, leave it where it is. If you ride harder on the twisties, you may want to kick it up a notch or two. The only thing is, the front remains the same and is soft from the factory so your limited there. I upgraded to a stiffer spring after having the bike for a couple weeks. In the curves I was getting a lot of push and the stiffer springs lessened it considerably.
smilie is offline
post #4 of 12 (permalink) Old 12-29-2018, 03:44 PM Thread Starter
tjkoko's Avatar
Year: 2015
Originally Posted by smurfy71 View Post
The best thing to do is try different settings and decide what you like best. Adjustments to the rear shocks will affect more than just the bumps. It affects cornering. Experiment. .....
Agreed! In this month's issue of MOTORCYCLE CLASSICS magazine, issue JAN/FEB 2019 VOl. 4 No. 3 it states on pp 55-6 concerning the new Royal Enfield INT 650, I'll paraphrase:
The rider kept missing "...apexes in the turns and had to back off the throttle to pull it back on line..." The solution was "...adding two turns to the preload adjusters on the Gabriel shocks...raised the rear height by 0.31 inches for more weight on the front wheel as well as tightening the effective head angle of the fork...fixed the problem....."
tjkoko is offline
post #5 of 12 (permalink) Old 12-29-2018, 06:51 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Great info, sometimes it pays to experiment.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #6 of 12 (permalink) Old 12-29-2018, 07:38 PM Thread Starter
tjkoko's Avatar
Year: 2015
With my very limited 'sperience, I could never have 'splained it better.
tjkoko is offline
post #7 of 12 (permalink) Old 12-29-2018, 08:13 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I really believe the best thing I did for a better feeling ride was to pump up the tire pressure. 36 front, 38 rear.
Factory settings are great for a nice cushy ride.
1983 750 Shadow
From the past=
post #8 of 12 (permalink) Old 12-30-2018, 11:51 PM
CoreyP's Avatar
Model: VT1100C
Year: 1999
I just tried different preload settings. The guy who owned the bike before me weighed in at maybe 160 and he had the shocks set at 1. He also progressive springs put in the front. I weigh in at 190 and found that I like 3 as the best setting with my tires pumped up to 38 pounds. My riding style is aggressive in corners so I like stiffer suspensions. More personal preference, just try out different settings and see what you like.
Here's the technical way to do it.
!999 VT1100C
CoreyP is offline
post #9 of 12 (permalink) Old 12-30-2018, 11:54 PM
CoreyP's Avatar
Model: VT1100C
Year: 1999
Tire pressure makes a big difference in the feel of the bike. I'm with you on pumping the tires up to the high range.
!999 VT1100C
CoreyP is offline
post #10 of 12 (permalink) Old 01-01-2019, 02:31 AM Thread Starter
tjkoko's Avatar
Year: 2015
Hmmmm, I just might try what you did.
tjkoko is offline
