Spark Plug Wires? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 01-25-2019, 10:00 AM Thread Starter
Model: VT600C
Year: 1993
Spark Plug Wires?
So, I just received my new coils for my bike. They came with the wires but there is no connection on the end for the spark plug.
Do I have to order these separately?
1993 Shadow VT600C
2001 Suzuki Kat 750
DieselDoctor is offline
post #2 of 15 (permalink) Old 01-25-2019, 10:29 AM
tc862011's Avatar
Spark Plug Wires?
What bike, you can unscrew some spark plug caps and transfer them, some you canít
1986 honda shadow vt700c - roxy
tc862011 is offline
post #3 of 15 (permalink) Old 01-25-2019, 01:17 PM Thread Starter
Model: VT600C
Year: 1993
Its my 93 VT600C
1993 Shadow VT600C
2001 Suzuki Kat 750
post #4 of 15 (permalink) Old 01-25-2019, 01:22 PM
tc862011's Avatar
Spark Plug Wires?
You can unscrew the coupling on the end of the old coil and remove the whole wire, did you replace because of bad wires or bad coil
tc862011 is offline
post #5 of 15 (permalink) Old 01-25-2019, 01:23 PM
tc862011's Avatar
I have done that a few times, remove the new wire and put the old wire back in place, make sure to clip a 1/8th of the wire to make a new connection
tc862011 is offline
post #6 of 15 (permalink) Old 01-25-2019, 01:27 PM Thread Starter
Model: VT600C
Year: 1993
I'm thinking its a bad coil. The rear cylinder gets plenty of fire but the front cylinder sounds like it isn't firing.
1993 Shadow VT600C
2001 Suzuki Kat 750
post #7 of 15 (permalink) Old 01-25-2019, 01:28 PM
tc862011's Avatar
Spark Plug Wires?
As long as the wires arenít worn or broken, should have no problems just swapping the old wires to the new coil, like i said before clip the ends so it makes a new connection
tc862011 is offline
post #8 of 15 (permalink) Old 01-25-2019, 11:28 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
If you transfer your old end caps measure them first with an ohm meter. They should show about 5000 ohms. If one is burned out you will still have a problem.
Here are some but you may need a couple of straight ones.
https://www.ebay.com/itm/4-Spark-plu...S!-1:rk:1:pf:0
https://www.ebay.com/itm/NEW-CB750-C...ONL6:rk:3:pf:0
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #9 of 15 (permalink) Old 01-28-2019, 10:00 AM Thread Starter
Model: VT600C
Year: 1993
Well, I decided to check my spark plugs first. I found a fouled plug on the front cylinder. All plugs were black but dry. Replaced the plugs and bike ran fine.
1993 Shadow VT600C
2001 Suzuki Kat 750
post #10 of 15 (permalink) Old 01-28-2019, 10:11 AM
h13man's Avatar
You rebuild your spark plug wires in the future if needed.
http://www.google.com/url?sa=t&rct=j...1iWFj1Cq7fTDGA
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
