Need Help Putting Back Together - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 22 (permalink) Old 03-07-2019, 08:28 AM Thread Starter
vabrokenarrow's Avatar
Model: Spirit 750
Year: 2007
Angry Need Help Putting Back Together
I traded my 1985 Rebel 250 with 15k miles for an 07 Spirit 750 with less than 3k, (even swap). The downside is that I need to clean, flush and partly reassemble the Spirit. My first obstacle is getting the batterybox/toolbox back in place. I can't figure out how he pulled it out because it won't go back in. Does anyone have any knowledge in this action?
02 Goldwing GL1800 - "Gold"
07 Shadow Spirit 750
78 CB750K -went separate ways
84 KZ750 - deceased
04 Shadow Aero - passed Down
05 Shadow Aero -went separate ways
vabrokenarrow is offline
post #2 of 22 (permalink) Old 03-08-2019, 08:16 AM Thread Starter
Model: Spirit 750
Year: 2007
I figured it out on my own. FYI, it's easy if you take the rear fender off.
84 KZ750 - deceased
post #3 of 22 (permalink) Old 03-08-2019, 11:40 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Good to hear you got it back in. Why was the battery box taken out? Customizing?
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #4 of 22 (permalink) Old 03-09-2019, 09:07 PM Thread Starter
Model: Spirit 750
Year: 2007
Because it wouldn't start. Now that it is pretty much together, I can't get it to start either. She acts like she is trying to start, but she won't.
84 KZ750 - deceased
post #5 of 22 (permalink) Old 03-09-2019, 11:06 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
So it cranks fine but won't fire?
Is there any funky wiring disturbed when the other guy was trying to start it?
Crank it a bit and drain the float bowls to see if the pump is working. And check for spark if there is fuel.
1983 750 Shadow
From the past=
post #6 of 22 (permalink) Old 03-11-2019, 07:00 AM Thread Starter
Model: Spirit 750
Year: 2007
Everything is as it should be @swifty2014 . I took the tank back off last night and plan to drain the tank, drain the bowls, clean it out and put it back together. I saw a trick on youtube that may help without having to actually remove the carbs.
84 KZ750 - deceased
post #7 of 22 (permalink) Old 03-15-2019, 10:28 AM Thread Starter
Model: Spirit 750
Year: 2007
I pulled the carbs off last night and the jets were very clogged. I have the smaller jet in both carbs that I can't seem to clear and I cannot find them online seperately. Anyone have a good idea on clearing the jets? I let it soak in seafoam overnight and will try to clear when I get home, using my tip cleaners. Any help would be appreciated.
84 KZ750 - deceased
post #8 of 22 (permalink) Old 03-15-2019, 01:03 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
The pilot jets are a very tiny drilling. At least mine were at size #40. Hard to find a wire strong enough. I have those welding tip cleaners and they didn't go down small enough. You can go up a size to help the idle mixture and get new jets at a dealer for $7-8.00.
1983 750 Shadow
From the past=
post #9 of 22 (permalink) Old 03-15-2019, 02:09 PM Thread Starter
Model: Spirit 750
Year: 2007
I was hoping to just clean mine out and apparently you have run into the same problem as me. I will run by the dealer after work and see what they can do for me. Thanks
84 KZ750 - deceased
post #10 of 22 (permalink) Old 03-15-2019, 02:42 PM
slowmovingtarget's Avatar
Model: Shadow ACE
Year: 2001
LOL I love questions that answer themselves. All joking aside as I was reading you orginal post that was my first though was remove the rear fender
Dress for the slide not the ride
slowmovingtarget is offline
Help putting Fork Dust Covers back on twentyfivemike Technical Discussion 1 11-27-2015 02:40 PM
Need help putting value on a scooter tigrzeye General Bike Discussion 1 08-15-2012 08:31 PM
putting my carbs back on my bike---HELP hughbie Technical Discussion 4 03-14-2012 10:25 PM
Do I need to flush the tank before putting back on? Dark Pony Technical Discussion 7 09-12-2011 04:06 PM
Putting baffles back in ?????? yukon Technical Discussion 7 07-27-2011 08:54 AM
