Stuck Oil filter - Page 3 - Honda Shadow Forums : Shadow Motorcycle Forum
post #21 of 28 (permalink) Old 03-27-2019, 04:06 PM
vito's Avatar
Originally Posted by smurfy71 View Post
I have a pair of these that I got for the large pvc fittings on my pool pump and filter. They are meant for oil filters though and work great on both.
Sitting on my VTX making Vroom Vroom noises.
https://www.hondashadow.net/forum/me...e71386-vtx.jpg
Sitting here thinking about opening the pool soon, and you post just what I need but hadn't thought of. Thanks!
vito is offline
post #22 of 28 (permalink) Old 03-27-2019, 04:13 PM
tjkoko's Avatar
Model: 2015 VT750C Aero
Year: 2015
...post duplicated by mistake.
I am coming from an older Triumph Tiger background.
tjkoko is offline
post #23 of 28 (permalink) Old 03-27-2019, 05:39 PM
smurfy71's Avatar
No problem.
2006 Shadow Aero 750, "Audrey" - Jan 2017 BOTM - Sold Oct 2018
2008 VTX 1300T - Oct 2018 Co-BOTM
smurfy71 is online now
post #24 of 28 (permalink) Old 03-29-2019, 12:55 PM
Mr Weekend's Avatar
I changed oil on a 150 hp Yamaha outboard a while back, and the nimrod who had installed the filter got it so tight that the gasket was totally compressed, and the filter housing was torqued against the mounting boss! I am Sasquatch, and it took all I had to pull it off with a metal strap wrench. I don't even own a rubber strap wrench these days.
Mr Weekend is offline
post #25 of 28 (permalink) Old 04-27-2019, 10:27 PM
Kaycee99's Avatar
Pipe wrench !
Kaycee99 is offline
post #26 of 28 (permalink) Old 04-28-2019, 07:14 AM
Chri s's Avatar
I had the same problem used a small G clamp easy 👍🏻
Chri s is offline
post #27 of 28 (permalink) Old 04-28-2019, 11:07 AM
Model: VT1100C
Year: 1989
Punch a screwdriver through it and turn.
1989 Shadow 1100
2006 KLR 650
Magnaryder02 is offline
post #28 of 28 (permalink) Old 04-28-2019, 02:18 PM
Model: 2007 Shadow 600
Since you're turning the bike upside down, as already suggested use a pipe wrench. All's needed is to rotate the filter a degree.
2007 Honda Shadow 600
RONW is offline
Oil Filter/Oil schin101 Technical Discussion 27 04-07-2012 09:23 PM
What oil filter/oil to use? crlshadow Technical Discussion 8 11-02-2009 09:06 AM
Oil, Filter & Final Drive Oil Change @ 600 Miles NJSPIRIT Technical Discussion 8 04-18-2008 09:46 PM
Oil Filter Oil cooler SHADOW 1100T Technical Discussion 4 03-29-2008 12:47 PM
9 hp increase oil filter/ synth oil combo 88shadeguy Technical Discussion 15 02-25-2007 10:59 PM
