Shift lever slop fix ? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 7 (permalink) Old 03-28-2019, 11:48 AM Thread Starter
Tellmymother's Avatar
Model: Shadow Ace Deluxe VT750CDD
Year: 2002
I found old posts about this problem but the solution was fuzzy. Poster said to use .0001 brass shims. First, .0001 thick would be a foil like material, second if correct where do you get this stuff. Or maybe I just need a new pivot bolt. I could add another washer I guess. Shifts a bit clunky but works fine. Just wondering if this was the cause. I fully realize a clunky shift can be caused by improper chain tension and clutch cable adjustment. Some guys say not to worry about it. But if you think about it this probably the most used joint on the bike and normal wear and tear would cause it to get sloppy over time. Here's a quick video...
Mother
Lonely out here on the perimeter, I can look back and see stars and planets in the distance, ahead only darkness ... but I've got matches . -- Mother
Merely reporting from out here on the perimeter, on the edge, but ain't fell off...yet.
Unwritten rules and regulations are not worth the paper they're not written on. -- Mother
Tellmymother is offline
post #2 of 7 (permalink) Old 03-28-2019, 12:20 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Brass shim stock is used in machine shops for set up on machines and other things. Why not make it easy and use nylon or polypropylene such as a milk jug and cut your own circle shim? Tough stuff nowadays.
Since it doesn't spin at any RPM it may last for years and easy to replace.
https://www.ebay.com/itm/brass-Shim-...ss!98042!US!-1
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 7 (permalink) Old 04-02-2019, 12:48 PM Thread Starter
Year: 2002
Mother and the wobble shaft
Got the shifter slop fixed for now. Got a new pivot bolt for $12, as you can see in the pictures the old bolt was worn down about .009, and gentlemen that is hardened steel. So if that is worn that much I'm sure the shifter lever is worn much more. Nevertheless I installed it and used the suggestion above to make a plastic washer from a milk jug (actually used the cap, it was thicker). See the video for the final slop, went from about 1/2” slop to about 1/8”, feels a lot better on my toe, firmer shift. The old post said to use .0001 brass shims, was a typo tho, should be .001. Shims were $17 so I went with the pivot bolt. It works for now, gonna order the shifter, $34 for the final repair. So, that's the fix for a sloppy shifter, new pivot bolt and new shift lever should do it. Pretty obvious answer but I had to know. The mount that holds all this was rust colored like Honda didn't even paint it. Same for the mount on the right side of the bike too. I had some blue engine paint to fix that, dried it with my high tech oven (blow dryer) looks a lot better, do the right side later. Anybody else's mount look like that ? Just wondering... I talk too much...
Mother
Here's a short video of the final slop, see the video in the above post for the initial slop.
ID:	261512   Click image for larger version
ID:	261514   Click image for larger version
post #4 of 7 (permalink) Old 04-02-2019, 01:40 PM
Year: 2000
They don't make brass shim stock in .0001 sizes.
Chuck_Michigan is online now
post #5 of 7 (permalink) Old 04-02-2019, 01:47 PM Thread Starter
Year: 2002
At the time I did not know that, as I am not a machinist. That's one of those things where people think "well, everybody knows that". Learn something every day.
Mother
post #6 of 7 (permalink) Old 04-02-2019, 02:02 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Good to hear you got it fixed.
A .001" (1/1000) inch shim would do you no good, let alone a 1/10,000 shim. A human hair is about .002 "
Plastic nowadays is so tough and slippery, that fix may last years.
1983 750 Shadow
From the past=
post #7 of 7 (permalink) Old 04-15-2019, 01:04 PM Thread Starter
Year: 2002
Final log, gear shifter slop
Got the new gear shift lever in. I was surprised it didn't include the rubber toe for it. That was actually the hardest part of the job was getting that rubber piece of the old lever. The old lever was worn out .006" so that plus the pivot bolt wear (.009) explains the slop. Total cost, lever and pivot bolt plus shipping $55. The washer worked fine but I figure I better get the parts while I can. Photos below if interested. This project is done, others in progress...
Mother
ID:	261926   Click image for larger version
Slop in driven sprocket gaals9999 Technical Discussion 2 08-17-2011 08:07 PM
Throttle slop... ELDogStar General Bike Discussion 5 08-29-2010 12:30 PM
Throttle Adjustment - slop in throttle andyf80 Technical Discussion 2 12-03-2008 01:41 AM
rear gear shift lever rockuharder Technical Discussion 2 04-24-2007 03:55 PM
Shift Lever E. Jay Stephens General Bike Discussion 3 04-21-2007 08:52 AM
