ignition module... bypass? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 7 (permalink) Old 03-28-2019, 01:22 PM Thread Starter
Model: vt1100
Year: 96
so... I've got this 96 vt1100. it wouldn't start. lights came on hit the start button, lights go dim but no cranking. I then replaced the battery thinking it was just too weak. it was not the battery. with the new battery installed i turned on the key and connected the + and - on the solenoid it cranked slow for a while then turned over. it idles just fine. so i think the ignition module is shot. can i just bypass it or does it control way more stuff?
Isaac is offline
post #2 of 7 (permalink) Old 03-28-2019, 01:26 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
If it idles it has spark, that is the main job of the ignition unit. Give more detail of how it runs.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 7 (permalink) Old 03-28-2019, 01:41 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Maybe you are saying it doesn't crank when it should. Then it may be the ignition switch or start switch contacts or the ground circuit for the solenoid such as the kickstand switch, clutch switch, etc.
1983 750 Shadow
From the past=
post #4 of 7 (permalink) Old 03-28-2019, 02:29 PM Thread Starter
Model: vt1100
Year: 96
I go about starting the bike like normal. It's in neutral, kickstand is up the kickstand light is off. Hit start while the kill switch is in run. The lights dim and nothing else happens. If I manually make the connection between the points on the solenoid it starts up and idles like normal. If I give it some gas it starts to sound off tho. Out of rythm.
Isaac is offline
post #5 of 7 (permalink) Old 03-28-2019, 04:30 PM
Definitely sounds like your start switch. Open the clam shell and look at the contacts.
jpr1968 is offline
post #6 of 7 (permalink) Old 03-29-2019, 09:25 AM
ABQ-Jammer's Avatar
Model: Spirit 750 VT750DC
Year: 2003
I agree with @jpr1968 , and suggest checking the start switch. It's got small copper contacts inside it, and when you push the button to start, it slides to make contact, completing the circuit. If that's either missing the contacts or has a wire broken to it, you'll see exactly what you have, lights dim, no crank, no start. Had mine go out on me at a local MC rally a few hours from home, with a wire that broke off. I managed to get the bike working using a bandaid, of all things, to hold the wire to the switch so it would start and run fine, and got me home, but I didn't get a chance to resolder it until the next weekend, and rode it all week to work with that bandaid holding it together.
(((=-JammeR-=)))
Ride Bells by blue flames & shadowride69 (THANKS!!)
'13 Harley Dyna Super Glide (FXDC)
ABQ-Jammer is offline
post #7 of 7 (permalink) Old 03-30-2019, 08:11 PM Thread Starter
Model: vt1100
Year: 96
Soooooo.... It was the solenoid. It was the only thing that wasn't doing what it was supposed to be doing and I really should have noticed sooner. Had to have a buddy come over and put fresh eyes on it but she fires right up again! Thanks for the help though guys. I really appreciate it!
Isaac is offline
Need Advice for Building Ignition Switch Bypass frogger Technical Discussion 2 10-27-2010 12:42 PM
Bad ignition module hoseppy Technical Discussion 8 03-28-2008 09:17 AM
1995 Shadow 1100 ACE ignition control module replacement bigmike2 Technical Discussion 2 06-05-2007 01:04 AM
Dynatek ignition module Red03ACE Technical Discussion 7 03-29-2007 01:09 PM
