Dinky little Master Cylinder??? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 10 (permalink) Old 03-30-2019, 09:50 PM Thread Starter
Big Shrek's Avatar
Model: VT500C
Year: 1983
OK, ordered a new Master Cylinder, ended up with this little 2"x3", if that, master cyl.
Compared to the old one that was 3"x4"?
Wondering if I was just sent the wrong one,
or if that's all a VT500C really needs??
At this point, just kind of sitting here amazed at it...
haven't checked if it fits yet
Ride paranoid. Don't let anything distract you.
Keep the paint side up, wear the lid & leathers.
Big Shrek is offline
post #2 of 10 (permalink) Old 03-30-2019, 09:55 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Probably your original one swelled up in the heat down there.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #3 of 10 (permalink) Old 03-31-2019, 12:58 AM
It really doesn't matter what size the master cylinder is as long as it can push enough fluid in a single stroke to activate the brake cylinder.
jpr1968 is offline
post #4 of 10 (permalink) Old 04-02-2019, 07:30 PM Thread Starter
Big Shrek's Avatar
Model: VT500C
Year: 1983
Sounds like it might be worth slapping on and seeing if it'll do the trick
I've got to check out the rest of the brake system first tho...
have been looking for a replacement brake caliper at the wheel,
but nothing on Amazon for that, unless I"m asking it the wrong questions.
post #5 of 10 (permalink) Old 04-06-2019, 08:22 PM
Model: Shadow Sabre
Year: 2005
If you want Honda OE master cylinder, you probably have to order from an authorized dealer. On Amazon, you may get something that will work, but not necessarily look like the original.
"Blackguy" is offline
post #6 of 10 (permalink) Old 04-06-2019, 11:32 PM
smilie's Avatar
I doesn't take a lot of fluid to activate the piston. Unless you've got some mongo sized, dual discs up front. Should be fine.
smilie is offline
post #7 of 10 (permalink) Old 05-29-2019, 08:58 PM Thread Starter
Big Shrek's Avatar
Model: VT500C
Year: 1983
You proved to be absolutely correct, size does not matter! LOL
However, the new master cylinder made all the old stuff,
start doing old stuff problems
So rebuilt the front caliper, replaced the front brake line...
and put in new pads, of course.
Now it'll stop on a dime
post #8 of 10 (permalink) Old 07-11-2019, 06:25 PM Thread Starter
Big Shrek's Avatar
Model: VT500C
Year: 1983
Couple months testing report...still doing great!
No issues at all. It's maintained its fluid level properly.
Quite happy!
post #9 of 10 (permalink) Old 07-11-2019, 11:47 PM
Thanks for reporting back on the longer term use.
So many reviews are of stuff are based on a couple of days experience.
CSRoad is online now
post #10 of 10 (permalink) Old 07-12-2019, 10:13 AM
Kryton's Avatar
Model: VT750C2F Spirit
Year: 2009
reservoir size is not important, master cylinder piston size and caliper piston(s) size(s) are what determine how hard/soft it feels and how well it works.
Kryton is offline
Master Cylinder Bore Sizes? rat Technical Discussion 5 08-02-2018 04:15 PM
clutch master cylinder, slave cylinder kit kevan Technical Discussion 1 03-09-2015 05:28 PM
Clip master link vs rivet master link Fredrix Technical Discussion 4 07-12-2010 08:13 PM
1993 Shadow clutch master cylinder angle question tinman Technical Discussion 2 03-14-2007 03:51 PM
1983 vt750c Clutch Master Cylinder joekato Technical Discussion 7 02-18-2007 02:27 PM
