Installing custom exhaust without re-jetting?? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 6 (permalink) Old 04-13-2019, 04:16 AM Thread Starter
Hello!
What "could" happend if you install a custom exhaust on a Honda Shadow without re-jetting etc.?
I owned before a Yamaha SR500 and installed a straight pipe on it without any re-jetting, and drove it for many years. That worked out fine for me!
Have any of you heard a mechanic say: "Damn, this engine was destroyed due to the aftermarket exhaust install"?
cromwell74 is offline
post #2 of 6 (permalink) Old 04-13-2019, 12:53 PM
Shouldn't be a problem.
jpr1968 is online now
post #3 of 6 (permalink) Old 04-13-2019, 12:59 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I didn't change jets with different mufflers I have put on. Just look at the color of your spark plugs after a ride to see how the mixture may need adjustment. The idle mixture screws will help to a certain amount also up to about 1/4 throttle.
The engine should never get destroyed unless the plugs are white and the engine is running hot and lean.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #4 of 6 (permalink) Old 04-13-2019, 01:06 PM Thread Starter
Will these aftermarket pipes fit my VT800?
https://www.jsk-webstore.fi/hd-custo...r-raw/01-0061/
Would you recommend these?
post #5 of 6 (permalink) Old 04-13-2019, 01:51 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I think they will fit fine.
But it says they are bare metal so you have to decide what look you want. Rust or paint?
And are they open tubes or have baffles? I can't tell.
If open they will be loud.
1983 750 Shadow
From the past=
post #6 of 6 (permalink) Old 04-14-2019, 03:23 AM Thread Starter
I donīt know if they are open tubes or not....can one assume that they have some kind of baffles inside?
The cost only 53 USD each so they are not that expensive.
Installing universal joint without removing swing arm TylerLew89 Technical Discussion 6 06-17-2014 08:51 AM
Re-installing exhaust rhody987 Technical Discussion 3 06-29-2013 03:16 PM
Custom exhaust without rejetting? johnny_i Technical Discussion 11 04-12-2012 03:53 PM
Exhaust smell after re-jetting amyw Technical Discussion 6 04-29-2008 08:48 AM
re-re-jetting? az232 Technical Discussion 2 06-22-2007 07:42 PM
