1983 VT500C tach woes - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 04-13-2019, 11:40 PM Thread Starter
I've read a few threads on this forum relating to the front cylinder camshaft holder breaking at the flared end where the tach cable connects to the tach gear. Before I seal the hole and switch the tach over to an electric, has anyone tried to JB Weld the broken tach flared end back on to the camshaft holder?
MightyFerengi is offline
post #2 of 4 (permalink) Old 04-13-2019, 11:51 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
If it is just the top area for the cable attachment it may work. But most break off down inside off the cam bearing bracket.Then maybe it can be aluminum arc welded.
Name:	vt500 tach drive.PNG
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #3 of 4 (permalink) Old 04-14-2019, 10:01 AM Thread Starter
Mine is broken just on the tach side. The rest of the bracket is undamaged. Looking at this, it seems someone tried to replace the little gasket/O-ring that seals the tach port on the cylinder cover with some kind of rubberized silicone. It's applied pretty thick. I bet that when they torqued down the cover after applying that silicone, it put too much pressure on that part and snapped it off.
So, now a little JB Weld action! I washed both parts with Dawn dishsoap twice and dried them immediately. After I mixed the JBW, I applied an even coat held it in place for a bit, then applied some rubber bands to keep it together for the recommended 24 hours.
ID:	261898   Click image for larger version
ID:	261900   Click image for larger version
post #4 of 4 (permalink) Old 04-30-2019, 05:20 AM Thread Starter
The weather finally cooperated this past weekend and I was able to put the repaired camshaft holder back on the cylinder and test it out. Works great! The tachometer is working properly and there is no oil leaking from the port area. I put 50 miles on it this weekend and got it up to 70 mph without an issue.
1983-84 Shadow VT500C Tach Repair? GoatSac Technical Discussion 2 09-04-2013 07:23 PM
1983 VT 750 Tach ? K5mitch Technical Discussion 7 07-17-2013 08:43 AM
1983 VT750 Brakelight/Tach Won't Work Kal40057 Technical Discussion 4 06-23-2013 03:12 PM
'84 VT500C Woes.... MrGrinch Technical Discussion 46 06-17-2011 02:05 PM
EZ-tach digital clamp-on tach???? What setting???? bvette85 Technical Discussion 1 06-25-2008 08:59 PM
