83 shadow 500 indicators - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 5 (permalink) Old 04-14-2019, 07:51 PM Thread Starter
Hey folks!
Just looking for some help - total noob here. I replaced the front indicators on my bike are they supposed to be on all the time when the bike is turned on? They still flash when I turn them on but not sure if they are supposed to be running lights?
Also - bike was running before winter charged the battery sounds like it wants to run but won't start. Its Still pretty damp and cold out this way. Did I mess it all up?
Thanks in advance!
shayneriley is offline
post #2 of 5 (permalink) Old 04-14-2019, 09:17 PM
Ramie's Avatar
Front should have running lights and turn signals. When you say you replaced the front indicators did you replace the bulbs or the whole assemblies?
I would try connecting a car battery, (with out car running) and see if it starts. If you left untreated gas in the carbs over the winter you may have to clean out the carbs but do that as a last resort.
Ramie is offline
post #3 of 5 (permalink) Old 04-14-2019, 11:52 PM Thread Starter
I replaced the entire assemblies. The rubber stems had to be replaced so I ended up doing the assemblies as well since they were falling apart.
I bought it at the end of the year so there was some old gas left in it unfortunately
post #4 of 5 (permalink) Old 04-15-2019, 01:36 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
You may have flooded it in the cold weather. Especially if the battery is cranking slow. Pull the plugs and see if they are black or wet and clean them. Go easy on the choke. My 750 is the same way, hard to start in cold temps and floods easy.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #5 of 5 (permalink) Old 04-15-2019, 09:55 AM Thread Starter
Thank you. I'll try that
Shadow Speedometer Indicators Damian Technical Discussion 16 10-17-2010 11:18 PM
How to - Indicators on buzzer + Photo stormrider Technical Discussion 25 10-19-2009 09:12 PM
valve adjustment indicators Juscruzn Technical Discussion 1 06-26-2008 07:09 PM
Indicators, running lights, brake, instruments out. Help! -Z- Technical Discussion 7 06-23-2008 05:49 PM
Wear bar indicators on tire waydawg Technical Discussion 4 08-12-2007 07:34 PM
