Electrical - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 04-18-2019, 01:44 PM Thread Starter
Shadowbobber2's Avatar
Electrical
For some reason my wires from my altornator are runing hot i have no clue about electrical on bikes. If some one knows why please leave a comment.
Shadowbobber2 is offline
post #2 of 8 (permalink) Old 04-18-2019, 07:24 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Remind us old guys what bike you have.
The wires may be warm as it charges the battery. The regulator gets hot also as it controls the charge rate. Check the 3 yellow wires at the connector to the regulator since they are well known to burn the connection.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 8 (permalink) Old 04-19-2019, 09:54 PM Thread Starter
I have an 03 ACE and yes the 3wires at the connection is burnt. What can i do?
post #4 of 8 (permalink) Old 04-19-2019, 09:55 PM Thread Starter
Where can i buy the parts to fix?
post #5 of 8 (permalink) Old 04-19-2019, 10:08 PM
smilie's Avatar
Most eliminate the plug altogether and just solder and shrink wrap, or use good crimp connectors on the three yellow wires. Do a search in the box at the upper right "3 yellow wire connector" and you'll find more info than you'll need to know.
smilie is offline
post #6 of 8 (permalink) Old 04-19-2019, 10:33 PM
Steve C's Avatar
Model: Non Shadow 1982 Honda GL500I SilverWing Interstate, two cyl. transversive "twisted"twin
Year: 1996 VT1100C2 ACE Shadow
I too recommend splice, solder and heat shrink tubing but if you want a new three wire connector;https://4into1.com/locking-connector...-series-3-pin/.
1996 VT1100C2 ACE Shadow,1982 Honda GL500I SilverWing,1980 AMF Roadmaster w/Minarelli V1 moped.."It's the journey not the destination" Ravens Roost Overlook milepost 10 Blue Ridge Parkway,Virginia
Steve C is offline
post #7 of 8 (permalink) Old 04-19-2019, 11:23 PM
Year: 2000
Cut, clean ends, crimp, heat shrink works for me.
Chuck_Michigan is online now
post #8 of 8 (permalink) Old 04-23-2019, 07:27 PM Thread Starter
Thank you every one for the advice it works just pefect.
** Rear Turn Signal Electrical Issue ** Help Electrical Guru's steeve725 Technical Discussion 7 11-04-2010 12:12 AM
Want to know how much electrical capacity a VT1100 has? ihavethespirit General Bike Discussion 8 03-12-2007 11:33 AM
Honda Electrical Connectors ShadowDave Technical Discussion 2 02-18-2007 02:42 PM
Electrical problem with starter & lights LynnH Technical Discussion 7 02-13-2007 01:20 PM
Electrical question ShadowRider2000 Technical Discussion 4 01-13-2007 09:39 AM
