Less Power Than Expected - 2004 VT1100C - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 35 (permalink) Old 04-22-2019, 03:32 PM Thread Starter
llaslo's Avatar
Good afternoon! Well, I have spent the last couple of weeks getting this bike back in order. I picked it up from my father-in-law about 2 weeks ago. Bike history is that he bought it new, and it only has 16K miles on it. It has sat pretty idle for the last few years. Here's what I've done:
  • Changed Engine Oil / Filter
  • Changed Brake Fluid
  • Changed Final Drive Oil
  • Changed air filter
  • Cleaned up all of the chrome, paint, etc.
Bike is now running really well. I still have some things to do:
  • New seat
  • New saddlebags
  • New windshield
  • Toolbag
  • Windshield Bag
  • Paint buffing
Anyway, all of that out of the way, the bike is running great. The only real issue I have is that the thing just has considerably less power than I expected. My previous bike was a 2004 Vulcan 800 Classic. It had considerably more power than this bike (now admittedly I did upgrade the air intake, pipes, re-jet the carbs, and put it on a dyno for tuning), but even so I would've thought 300CC more would have made a significant difference. Don't get me wrong, I'm not looking for a sportbike feel here. I realize it's a cruiser, I'm just curious of what your thoughts are. TIA!
2004 VT1100C
Aftermarket Add-Ons (so far):
  • Sissy Bar
  • Saddlebags
  • Windshield
llaslo is offline
post #2 of 35 (permalink) Old 04-22-2019, 04:02 PM
Kris Carr's Avatar
Model: VT500C
Year: 1984
that bike left the factory with about 60 hp with a dry weight of around 550 lbs. Thats not overly impressive from the start. then add a bunch of weight for your bags and accessories and you get a bike that may be comfortable but not fast. the 800 vulcan probably made close to the same hp but is a smaller bike so would lolely have a better power to weight ratio despite its smaller engine
Kris Carr is offline
post #3 of 35 (permalink) Old 04-23-2019, 09:01 AM
h13man's Avatar
Well I see no mentioning of carb cleaning. Might put a 1/3 can of Seafoam/Berryman in fresh tank of gas and see if you get some response out of the ole' girl. Did you check the date code on the tires? A set of these made huge difference in wrist comfort w/o any mod's to cable's etc. https://www.jpcycles.com/product/500...dium-handlebar
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #4 of 35 (permalink) Old 04-23-2019, 11:13 AM Thread Starter
llaslo's Avatar
I did check the tires, and they need to be replaced. It's on my shortlist as well. I will definitely check out the handle bars. Also, I'm not a huge fan of seafoam; however, I think it might be a good idea to remove and rebuild the carb. I've never really done much with carbs (not since I was 16, and even then I didn't really understand what I was doing). How hard of a job is this to rebuild / adjust the carb?
2004 VT1100C
  • Sissy Bar
  • Saddlebags
  • Windshield
llaslo is offline
post #5 of 35 (permalink) Old 04-23-2019, 11:26 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
If you have only 1 carb it is easy. Mostly just cleaning any debris in the float bowl and inspecting and cleaning the pilot jet which has a very small drilling through it. If there is no major corrosion spray carb cleaner may be all you need. Inspect the rubber diaphram on the slide carefully for damage also.
This guy has some great videos.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #6 of 35 (permalink) Old 04-23-2019, 03:11 PM Thread Starter
llaslo's Avatar
https://www.youtube.com/watch?v=NRFMwoGAR2U
Does my bike have just a single carb? 2004 VT1100C?
2004 VT1100C
  • Sissy Bar
  • Saddlebags
  • Windshield
llaslo is offline
post #7 of 35 (permalink) Old 04-23-2019, 03:18 PM
blupupher's Avatar
Model: VT1100C
Year: 1994
No, 1100 are all twin carb.
Quite a few youtube videos on it, this guy does a good how to on it IMO.
And another how to get them off:
And another:
1994 VT1100C
Starfire 185/65/15 rear tire (Darkside)
Perilli MT66 Route 110/90/19 front tire
Progressive 430HD Rear Shocks
Mustang Seat
National Cycle Windscreen
blupupher is offline
post #8 of 35 (permalink) Old 04-23-2019, 03:24 PM Thread Starter
llaslo's Avatar
Thanks! That's what I thought. I'm going to buy a service manual and watch some videos. This can't be that hard to do.
2004 VT1100C
  • Sissy Bar
  • Saddlebags
  • Windshield
llaslo is offline
post #9 of 35 (permalink) Old 04-23-2019, 08:59 PM
Year: 2000
Do they need cleaning?
Chuck_Michigan is offline
post #10 of 35 (permalink) Old 04-23-2019, 09:11 PM
Year: 2000
You said the bike was running great, why do you feel you need to rebuild the carbs? If the bike is running smoothly now throughout it's rpm range, from starting it up, to idle to wide open throttle, a rebuilt carburetor is not going to make it run smoother or produce a lick more horsepower. My 2000 1100VT (same as yours) is the slowest bike in my collection, but I didn't buy it for speed. It's a great cruiser, runs all day long at expressway speeds without overworking the motor, and gets great gas mileage.
If your new to bikes and aren't real comfortable around carburetors and the many ways you can screw them up while trying a complete rebuild, you might wish you had just left well enough alone.
If you don't care for SeaFoam, run an ounce of Lucas Fuel Injector Cleaner through each fillup, and the carbs will last forever without needing to be rebuilt.
Just my opinion, but it's your bike, so take the advice with a grain of salt. Enjoy that bike...
Gas tank leak much worse than expected! 06spirit750 Technical Discussion 14 08-07-2014 10:53 AM
MPG still lower than I expected AdamSean General Bike Discussion 15 06-28-2013 09:06 AM
'86 VT1100C - Dies when it has less than 1.5 or so gallons e5dab Technical Discussion 3 03-21-2009 09:11 PM
