85VT700 Ignition Issues - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 04-23-2019, 08:48 AM Thread Starter
ShadowGeezer's Avatar
Model: VT700
Year: 1985
Question 85VT700 Ignition Issues
Does anybody have a spec for testing the CDI modules for 85 VT700, or do I have to swap modules to figure out if one is bad? Are the CDI\s somewhat interchangeable across model years?
Background: Rebuilt carbs and engine to 0-time. Fixed issue with bad fuel pump relay and replaced fuel pump, so getting plenty of fuel. Engine starts and runs fair with some roughness; but hesitates initially when throttle jazzed. After engine warms up, starts running like crap, Only smooths out at about 4000 RPM, but likely because rotation is fast enough to mask the miss. Feels like hitting intermittently on one ore both cylinders.
ShadowGeezer is offline
post #2 of 8 (permalink) Old 04-23-2019, 12:47 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
There are no tests in the manual unfortunately.
Swap side to side to see if it make any difference. Maybe a coil is breaking down also. Spray water on the coils and wires at idle and revved, to see if they arc over.
What color are the plugs? If too lean or too rich it may act like that.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 8 (permalink) Old 04-23-2019, 02:07 PM Thread Starter
Model: VT700
Year: 1985
I'm liking the idea of checking the coils as well. The CDI units are on the rear fender away from the engine, but the coils are up front where they could easily be affected by engine heat. I also need to look at the part numbers on the CDIs to see if they are swappable. I'll keep you posted... THX
post #4 of 8 (permalink) Old 04-23-2019, 02:15 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
The coils have been know to crack with age. Also measure the plug wire end caps should be about 5000 ohms resistance. And the coils can get corrosion where the wire screw in.
1983 750 Shadow
From the past=
post #5 of 8 (permalink) Old 04-23-2019, 06:32 PM
You may well be right on the ignition being a problem, but I have one question based on your description.
Do you have the full air filter assembly hooked up, typically Honda Shadows run like crap without it?
CSRoad is offline
post #6 of 8 (permalink) Old 04-23-2019, 07:29 PM
Actually that sounds like a carburation issue.
jpr1968 is offline
post #7 of 8 (permalink) Old 04-23-2019, 07:29 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
That is a big 10-4 on the air intake tubing !
1983 750 Shadow
From the past=
post #8 of 8 (permalink) Old 04-24-2019, 01:34 PM
Derek86VT700C's Avatar
86 VT700C here... found a huge crack in one of my coils. Replaced. Runs alot smoother
Derek86VT700C is offline
Floorboards 85VT700 Bean Member Introductions 2 03-12-2012 06:48 PM
86 VT700 engine into 85VT700 frame 750hdgmd Technical Discussion 2 05-19-2011 08:20 AM
85vt700 rear fender mod vstar General Bike Discussion 0 05-21-2008 08:54 PM
Doin' the happy dance, 85VT700 re-jet succ-cess!!! Shogun Technical Discussion 2 05-14-2007 09:42 PM
Tank bib 85VT700 mindfungus General Bike Discussion 3 02-24-2007 01:32 PM
