VT500E whining noise - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 17 (permalink) Old 04-30-2019, 11:11 AM Thread Starter
Hi.
Some time ago I bought this 1988 VT500 E with supposedly 58 k on the counter. It's a well handling bike, although not the prettiest design.
Recently, it started making a whining noise when warm and only at idling engine speed. The sound will disappear as soon as the revs goes up and return at idling speed. If the engine has been turned off for a few minutes, the sound is gone, but will return after a few minutes driving. At first, the sound seem to come from the right side of the engine (clutch-bearing?), but I do now suspect the water pump may cause the noise. Does anyone recognise this problem?Thanks.
franne
franne is offline
post #2 of 17 (permalink) Old 04-30-2019, 04:44 PM
Tellmymother's Avatar
Model: Shadow Ace Deluxe VT750CDD
Year: 2002
My has always whined, nature of the beast I guess.
Mother
My PC has gotten real slow lately, a classic symptom of Sh!t Buffer Overflow, once your sh!t buffer overflows, it's over man, especially if there is a fan nearby. -- Mother
Unwritten rules and regulations are not worth the paper they're not written on. -- Mother
Tellmymother is offline
post #3 of 17 (permalink) Old 05-01-2019, 12:08 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
The water pump is on the lower left side. Get a cheap stethoscope from Harbor Freight to pin point the sound. Or even a few feet of hose held up to your ear.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #4 of 17 (permalink) Old 05-02-2019, 02:57 PM Thread Starter
Mother
https://youtu.be/2Bg57tF-QyU
Thanks for sharing this with me, Mother.
I have been thinking of just trying to forget about the noise, but it's a rather annoying sound, so I'll try to solve the problem.
The noise from your bike is a wee bit more pleasant than my noise. I'll see if I can upload some sound.
I'll let you know, if I succeed ti fix the problem.
//franne
franne is offline
post #5 of 17 (permalink) Old 05-02-2019, 03:06 PM Thread Starter
Thanks for your advice, Swifty.
My daughter in law is a doctor, so she probably has such a tool in her doctor's bag. I'm sure her patients won't mind an oily spot on their chest
franne is offline
post #6 of 17 (permalink) Old 05-02-2019, 07:02 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Just wrap the end in a plastic baggy and no one will know the difference.
1983 750 Shadow
From the past=
post #7 of 17 (permalink) Old 05-03-2019, 05:39 AM
Big Shrek's Avatar
Model: VT500C
Year: 1983
If you take a look at a bike known as the Yamaha Vision...you'll see certain similarities...can't remember which one came first, but the Vision was a 550. Anyway, they had a slightly better looking & much larger windshield, so if you are a semi-decent welder and found one, you could upgrade your shield by welding on the bracket. Everything built in the 80's could be switched around if you had some welding skills
Meanwhile, deep cleaning of an engine is sometimes a neccessary evil. Running Multiple radiator flushes on a Saturday pretty much kills a Saturday, but your bike will thank you for it! Ain't a bad idea to do it for ALL your vehicles at the same time...at least 3 radiator flush bottles per vehicle, lots of distilled water, and rad fluid to refill when it's all done.
Also...after that's done, oil flush/change are the next Saturday's chore. Also realize that synthetic oils can make a bike sound quite different...so don't be afraid to experiment between Standard and Synthetics.
ID:	262384   Click image for larger version
Name:	1983 Yamaha XZ550 VISION.jpg
ID:	262386   Click image for larger version
Ride paranoid. Don't let anything distract you.
Keep the paint side up, wear the lid & leathers.
Big Shrek is offline
post #8 of 17 (permalink) Old 05-07-2019, 04:49 PM Thread Starter
Thanks Big Shrek.
I must try this radiator flush, but meanwhile the noise has disappeared. My bike probably saw me with the stethoscope around my neck
About fairing, I must confess I did actually have a 550 Vision a few years ago. But I did not like it's fairing (nor the bike's handling). Maybe I'll do something else and make a café racer out of the Honda next winter.
But thank you for your ideas.
franne is offline
post #9 of 17 (permalink) Old 05-08-2019, 11:58 AM
Originally Posted by Big Shrek View Post
Meanwhile, deep cleaning of an engine is sometimes a neccessary evil. Running Multiple radiator flushes on a Saturday pretty much kills a Saturday, but your bike will thank you for it! Ain't a bad idea to do it for ALL your vehicles at the same time...at least 3 radiator flush bottles per vehicle, lots of distilled water, and rad fluid to refill when it's all done....
I enjoy the Chris Fix videos and if you have decided to do a rad "flush" at least this one shows how, however this procedure is not required and NOT recommended by Honda (or Nissan, GM, Ford etc.). The dark color of "old" coolant is meaningless. The coolant and the flush are environmentally hazardous so flushing creates additional environmental issues. Honda specifically warns against using any aftermarket "flushes".
As with most automotive consumables, coolants and cooling systems have vastly improved over the years so that typical coolant change is once every 5 years (for instance the 2001 Honda Accord recommended first coolant change is 120,000 miles).
G.
gdb069 is offline
post #10 of 17 (permalink) Old 05-08-2019, 04:48 PM Thread Starter
Well, to be honest, I have tinkered with quite a lot of old cars and bikes for the past 50 years, but I have never flushed a cooling system. Admittedly, I have done other nasty things to the cooling system in order to try to repair a radiator or a cracked cylinder head like putting an egg or other magical stuff into the cooling system ;-(.
However, the idea of flushing the internals of the human body seems to be very popular in these days, so maybe this goes for our beloved bikes as well
Thanks for your input B
franne is offline
Vt500e franne Member Introductions 1 04-29-2019 07:30 PM
VT500E styling franne Member Introductions 0 04-29-2019 03:27 PM
Whining noise Granite Man Technical Discussion 6 10-10-2009 02:08 AM
98 ACE Engine makes whining noise lynnsshadow Technical Discussion 4 09-25-2009 02:11 PM
Whining Noise Sandy6 Technical Discussion 8 06-04-2008 12:26 PM
