Is full synthetic 0W-40 oil Ok for my VT600CD? What about high mileage synthetic? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 24 (permalink) Old 05-02-2019, 11:40 PM Thread Starter
cruzinrocker's Avatar
I'm considering 3 different oils for my 97 VT600CD, all of which are Amazonbasics oil because their oil performed extremely well in tests on the Project Farm youtube channel... and it's inexpensive.
1) 0W-40 Full Synthetic ( It says European Formula... dunno if that would truly make a difference)
2) 10W-40 High Mileage Synthetic Blend ( My VLX isn't high mileage, 12k... not sure if it makes a difference)
3) 10W-40 Conventional (May be the most wise decision)
What oil are ya'll running, any input on these formulas/weights?
1) https://smile.amazon.com/AmazonBasic...r=8-6-fkmrnull
2) https://smile.amazon.com/AmazonBasic...r=8-3-fkmrnull
3) https://smile.amazon.com/AmazonBasic...r=8-3-fkmrnull
cruzinrocker is offline
post #2 of 24 (permalink) Old 05-03-2019, 12:11 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
I don't know what advantage it would be to have a 0 weight oil unless you are in a very cold area. But watch out that none of them are automotive oils with the energy conserving badge because they may cause a slipping clutch. They have to be JASO-MA oils for the bikes. None of the Amazon oils show JASO specs.
I use Rotella T4 15-40 and it works fine. I tried the Rotella T6 Synthetic and on my old engine, the cam bore rubber plugs started to leak faster since the synthetic can clean out old sludge build up.
https://www.walmart.com/ip/Shell-Rot...llon/181236405
This may be a problem with the clutch=
Friction-Reducing Formula
AmazonBasics full-synthetic motor oil creates a protective coating that helps reduce wear on engine components. By minimizing friction from an engineís in-contact moving parts (which wastes otherwise useful power), the motor oil helps enhance fuel economy and promotes better power output and performance.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 24 (permalink) Old 05-03-2019, 12:12 AM
Don't use those oils. They have friction modifiers and that' not good for wet clutch bikes.
jpr1968 is offline
post #4 of 24 (permalink) Old 05-03-2019, 12:27 AM
Model: VLX 600
Year: 2003
Since you asked, I use 5w40 RotellaT6 in my 4 motorcycles. And a lot of other other things. It can usually be had for around $22/gal.
gonerydin is offline
post #5 of 24 (permalink) Old 05-03-2019, 03:11 AM
tjkoko's Avatar
Model: 2015 VT750C Aero
Year: 2015
The lubricants I use are listed in The Owner's Manual by Honda. And I purchase them from the local Honda shop at prices that aren't over priced. And this expenditure at the Honda saves me lots of time from reading threads on lubricants.
I am coming from an older Triumph Tiger background.
tjkoko is online now
post #6 of 24 (permalink) Old 05-03-2019, 06:10 AM
Year: 2000
I used to subscribe and watch that guy's videos until he started making some wild ass claims based on VERY little testing. Seems today he is more interested in pumping out the videos just for the sake of making them than doing any controlled testing. I wouldn't trust anything he says anymore and have quit watching him.
As for which oil to use in my bikes, I simply use what the manufacturer of my bike recommends. The reason is because the guys who built my bike know more about what it needs than random people on the Internet or Youtube.
Chuck_Michigan is offline
post #7 of 24 (permalink) Old 05-03-2019, 10:23 AM
h13man's Avatar
Rotella T6 used to be awesome but due to EPA mandates the formula as been changed to the point that Ford will void warranties if one uses it. I used it last fall and I had increased shifting noise thus my old Toyota beater is using it now. Went to Valvoline 4T dino for now. Basically to use synthetic now will cost a minimum of $30+.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #8 of 24 (permalink) Old 05-03-2019, 11:34 AM
Tellmymother's Avatar
Model: Shadow Ace Deluxe VT750CDD
Year: 2002
I had a problem with slight clutch slippage not too long ago. I just used any motor oil I had, WRONG ! I changed oil to a JASO-MA oil, problem went away.
Mother
My PC has gotten real slow lately, a classic symptom of Sh!t Buffer Overflow, once your sh!t buffer overflows, it's over man, especially if there is a fan nearby. -- Mother
Unwritten rules and regulations are not worth the paper they're not written on. -- Mother
Tellmymother is offline
post #9 of 24 (permalink) Old 05-03-2019, 12:31 PM
blupupher's Avatar
Model: VT1100C
Year: 1994
JASO MA is the oil approval you need.
Car motor oils (which is what the Amazon Basics oils are) are not designed for shared sump motorcycles. Many have friction modifiers in them that are very bad for wet clutches (they will say "Energy Conserving" on the API donut on the back, the 3 weights you linked do not say it).
Amazon Basics motor oil is a fine oil for a car, but not a first, second or third choice for a bike IMO.
If you are wanting to be cheap, that is fine, I am also cheap.
Supertech 15w-40 Heavy Duty Engine Oil (HDEO) will work just fine for your bike, cost $10/gallon at Walmart. It is not JASO MA certified, but many use it with no issues (myself included). No it is not synthetic, but will easily do 3000+ miles per change.
Other HDOE's will also work, because that also do not contain friction modifiers.
1994 VT1100C
Starfire 185/65/15 rear tire (Darkside)
Perilli MT66 Route 110/90/19 front tire
Progressive 430HD Rear Shocks
Mustang Seat
National Cycle Windscreen
blupupher is offline
post #10 of 24 (permalink) Old 05-03-2019, 12:51 PM
Model: VLX 600
Year: 2003
Iíve not noticed any problems. And RotellaT6 is still on Fordís list of approved oils meeting WSS-M2C171-F1.
Full synthetic, synthetic blend, or non synthetic??? Danfriday Technical Discussion 24 07-26-2011 04:56 PM
Slight running issue on a 94 VT600CD At 40 mph Spre Technical Discussion 0 03-29-2011 10:03 AM
Rotella T6 5w-40 Synthetic Oil tsmith Technical Discussion 24 03-26-2011 03:43 PM
Rotella T 5w-40 vs Rotella T6 5w-40 BobZ06 General Bike Discussion 0 08-03-2010 09:58 AM
Considering making Rotella 5W-40 Synthetic my main oil. jtm-45/dr504 Technical Discussion 15 06-26-2007 11:32 PM
