Non-starting issue - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 28 (permalink) Old 05-05-2019, 01:40 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Make sure you have the proper free play in your clutch cable because if it has too much slop it won't release correctly.
Slop is sort of a lazy mechanical way of saying something is out of tolerance. Like "this worn piston has too much slop".
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #12 of 28 (permalink) Old 05-06-2019, 02:44 PM Thread Starter
Model: Aero
Year: 2007
non-starting issues
Illness and bad weather prevented me from making any progress yesterday; but today I went out and readjusted the cables and it started --- however, it was short lived because after a minute or two it killed. Further attempts at restarting were unsuccessful. One further question for you! ***What does the fact that it will start every 15 or so attempts mean? Can that possibly be related to the adjustment of the throttle cables?*** I always thought that maladjusted throttle cables could put you at risk for injury or death, but I never imagined it would prevent the bike from consistently starting.
Space Force 1 is offline
post #13 of 28 (permalink) Old 05-06-2019, 08:44 PM Thread Starter
Model: Aero
Year: 2007
non-starting issues
Originally Posted by Ramie View Post
You should have some slop in the throttle when you twist it back and forth. There are two different adjustments on the push pull cables, one up towards the grip and one down next to the carbs. I've always found the one by the carbs easier to adjust but you may have to lift up your tank a little.
It's also possible you messed up the kill switch wiring when changing out the cables.
I think you were correct in regards to the kill switch wiring. There appears to be a shortage. There is a sweet spot in the corner of the starter switch that gets me started, but only that one spot. It seems as if I am going to have to get a new starter switch or maybe this one can be cleaned. Thanks for your assistance & direction.
post #14 of 28 (permalink) Old 05-07-2019, 01:50 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
The clutch and throttle cables should not keep it from starting, if it is neutral and the throttle is closed it should start.
1983 750 Shadow
From the past=
post #15 of 28 (permalink) Old 05-07-2019, 02:34 PM Thread Starter
Model: Aero
Year: 2007
non-starting issues
I am pretty certain there is a short in the switch assembly. The starter switch only responds when a certain spot in the corner is pushed, otherwise nothing. When I get home this evening I will go inside it and see what debris or corrosion might be shorting it out. Thanks a lot for your assistance!
post #16 of 28 (permalink) Old 05-10-2019, 12:48 AM
buschchris1's Avatar
Adjust tour idle. Open it up more and then see if it runs then turn it down to the spec RPM it should be. Probably 900RPM. Also check the choke. If pulled out its closing the the air intake starving it. Push it back in. That or you reversed the open and close cables on the throttle.
buschchris1 is offline
post #17 of 28 (permalink) Old 05-10-2019, 06:56 AM
vabrokenarrow's Avatar
Model: Spirit 750
Year: 2007
@Space Force 1 This is a good video for adjusting throttle cables. This guy is a mechanic at my local Honda dealer and is very good with what he does.
02 Goldwing GL1800 - "Gold"
07 Shadow Spirit 750
78 CB750K -went separate ways
84 KZ750 - deceased
04 Shadow Aero - passed Down
05 Shadow Aero -went separate ways
vabrokenarrow is offline
post #18 of 28 (permalink) Old 05-11-2019, 02:49 PM Thread Starter
Model: Aero
Year: 2007
Over the last several days we have been having flood like conditions with constant downpours so I haven't been able to get outside with the bike; however I have disassembled the right hand handlebar switch with the idea of cleaning out any corrosion that may have built up from outside storage. I thought that maybe the problem is with the starter switch. I think the weather may clear enough tomorrow that I can reassemble it and see if it works.
I had no idea that throttle cables played any part in the bike starting or not. I have changed throttle cables 3 times (this is the 4th) with no resulting issues with starting. When I reassemble the switch assembly I will pay fuller attention to the adjustments of the cables.
Thank you for your insight & advice.
post #19 of 28 (permalink) Old 05-14-2019, 10:17 PM Thread Starter
Model: Aero
Year: 2007
I made a mistake in thinking that my issue was related to a short or corrosion in the stop switch/starter switch. I never suspected it had anything to do with the throttle cables. In any event, I didn't notice before but now I see that when I click the starter button fluids (coolant?) drip out if the bike doesn't start. On the few occasions that it does start there is a sort of whiny sound & the fluids pour out. Does that sound like it has anything to do with the carburetor? If it were the carb would that prevent it from starting at all? The attachments are to show you where the leakage is.
ID:	262620   Click image for larger version
ID:	262622   Click image for larger version
post #20 of 28 (permalink) Old 05-15-2019, 10:41 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
If you see drips from that black rubber boot area it is the oil pressure switch. It could have a leak and a loss of oil but would not keep it from cranking or starting. But check your oil level to be sure it is not low, now that you have seen leaking.
The throttle cable itself won't cause a no start. Just don't open the throttle while cranking, that usually works best.
If it will crank all the time, but not fire up then it is fuel or electrical related.
1983 750 Shadow
From the past=
Non-Starting/Engine Reving Space Force 1 Technical Discussion 14 09-14-2018 04:03 PM
Non-start issue - Sidestand switch? Menhir Technical Discussion 20 07-17-2015 07:49 PM
carb issues, hard starting cold to hard starting worm tank83750 Technical Discussion 2 08-10-2011 02:47 AM
Starting Issue Wedgie Technical Discussion 4 07-27-2007 06:05 PM
83-86 VT750 and VT700 hard starting issue's Need Wiz Mech!!! fiero880 Technical Discussion 17 02-27-2007 07:36 PM
