Non-starting issue - Page 3 - Honda Shadow Forums : Shadow Motorcycle Forum
post #21 of 28 (permalink) Old 05-15-2019, 10:22 PM Thread Starter
Model: Aero
Year: 2007
Originally Posted by swifty2014 View Post
If you see drips from that black rubber boot area it is the oil pressure switch. It could have a leak and a loss of oil but would not keep it from cranking or starting. But check your oil level to be sure it is not low, now that you have seen leaking.
The throttle cable itself won't cause a no start. Just don't open the throttle while cranking, that usually works best.
If it will crank all the time, but not fire up then it is fuel or electrical related.
The leakage is not from the oil pressure switch, but it is leaking onto it from above. From the coloration it could be coolant, but it also has a gassy smell. When I was replacing the throttle cables I noticed what appeared to be a small leakage (a few drops) from the water tubes that connects to the carburetor.
The oil is fine - I haven't lost any, but I do seem to be losing gas. Each evening I put a little in (hoping to get it started) but seem to have less the following day when I remove the tank. Yes it will crank each & every time, and for a brief moment it seem that it wants to fire up, & occasionally it did but it is usually short-lived. Today I checked the fuel line. I admit I am much better at fixing something than I am at diagnosing problems. My problem is that I don't know what the problem is LOL.
Space Force 1 is offline
post #22 of 28 (permalink) Old 05-15-2019, 10:37 PM
Big Shrek's Avatar
Model: VT500C
Year: 1983
Water tubes to the carb??
Sounds like those are vacuum tubes...shouldn't have any water in 'em tho...gas might be present, if there is a...whatchamacallit...do a petcock rebuild because your regulator diaphram is probably cracked. Well, honestly probably all the rubber inside there is shot. Heat & age can kill the inner workings of a petcock as quickly as ten years, also somewhat dependant on where you park it/store it. Shade/bike cover is good, direct sunlight is bad.
That should solve your gas leak issue.
Oh, also check your fuel tank lid, sometimes that gasket wears out and the gas will evaporate right out the top, especially in warmer weather.
Ride paranoid. Don't let anything distract you.
Keep the paint side up, wear the lid & leathers.
Big Shrek is offline
post #23 of 28 (permalink) Old 05-16-2019, 11:12 AM
Kryton's Avatar
Model: VT750C2F Spirit
Year: 2009
The throttle plate needs to be closed for the slow jet to siphon fuel into the air stream. If the throttle plate is open too far the slow jet doesn't draw enough fuel and the mix will be too lean to idle.
Kryton is offline
post #24 of 28 (permalink) Old 05-16-2019, 01:38 PM Thread Starter
Model: Aero
Year: 2007
Yes! Water hoses are connected to the carb and so are vacuum tubes - in any event, your suggestions were well received. Thank you!
ID:	262644   Click image for larger version
post #25 of 28 (permalink) Old 05-16-2019, 01:57 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
So the water hoses could be for carb heat to keep them at a proper temp to run efficiently and clean emissions. Cars have manifold heating also with carbs . Some bike carbs have electrical connectors with heating elements in the bowls.
But to find the source of the leak wrap paper towels around the hoses you suspect and run it and look for wet spots.
Maybe all that is needed is to snug up the hose clamps.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #26 of 28 (permalink) Old 05-20-2019, 01:37 PM Thread Starter
Model: Aero
Year: 2007
Talking
Happy to report that I am back on the road again apparently, "all that was needed was to snug up the hose clamps." Thanks again!!!
post #27 of 28 (permalink) Old 05-20-2019, 02:40 PM
Ramie's Avatar
Glad you got it running, enjoy.
Ramie is offline
post #28 of 28 (permalink) Old 05-21-2019, 01:25 AM Thread Starter
Model: Aero
Year: 2007
Yeah! Thanks for the input, I appreciate it.
Non-Starting/Engine Reving Space Force 1 Technical Discussion 14 09-14-2018 04:03 PM
Non-start issue - Sidestand switch? Menhir Technical Discussion 20 07-17-2015 07:49 PM
carb issues, hard starting cold to hard starting worm tank83750 Technical Discussion 2 08-10-2011 02:47 AM
Starting Issue Wedgie Technical Discussion 4 07-27-2007 06:05 PM
83-86 VT750 and VT700 hard starting issue's Need Wiz Mech!!! fiero880 Technical Discussion 17 02-27-2007 07:36 PM
