VT1100C 85 problem - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Unread 05-08-2019, 04:44 PM Thread Starter
VT1100C 85 problem
Hi people.
I'm in desperate need of help. I'm working on this bike for a friend. Bike last ran in june 2018. Out of the blue it wouldn't run anymore. In oktober I got started on it. I suspected the carbs so first I took them off and took them apart. Cleaned all the parts in an ultrasonic bath. Put everything back together. It wouldn't run. So I started to check all the ignition components. Turned out the camshaft sensor on the rear cilinder was faulty. I got a second hand one. The bike started but ran on front cilinder only. Rear cilinder didn't work en sparkplug came out soaking wet. So back to the carbs. Took them apart again. Checked float level, vacuum membrane, the works...all ok. Bike still runs on front only. Did compression test; front 10 bar, rear 11 bar. Did a measurement of all the ignition components again and all are within the workshop manual specifications. Only thing I can't check are both CDI's. Replaced both; bike still runs on front cilinder only.
Now I'm on the end of my knowledge.
Does anyone has an iedear??
I'm lost.
Hans
Verstuurd vanaf mijn SM-G920F met Tapatalk
Dinopaps is offline
post #2 of 12 (permalink) Unread 05-08-2019, 07:00 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Did you actually see there is spark or not on the rear cylinder?
If not test the pulse generators on the right end of the crank to see if one is bad.
They usually measure about 450 ohms. And some have failed when hot.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #3 of 12 (permalink) Unread 05-09-2019, 12:57 AM Thread Starter
If I cranck the engine with the plug outside on the block, I actually see a spark. And like I said; I checked all ignition components according workshop manual specs and all are within given specs, including pulse generators. The bike isn't running long enough to get hot. It runs on one cilinder from the start.
Dinopaps is offline
post #4 of 12 (permalink) Unread 05-09-2019, 01:46 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
If you have the air intake tube off get it running and spray a little carb cleaner into the dead cylinder carb to see if it picks up for a little bit.
Are the carbs synced? Both throttles need to work equally.
1983 750 Shadow
From the past=
post #5 of 12 (permalink) Unread 05-09-2019, 05:33 AM Thread Starter
After running for 20 seconds on front cilinder and a few backfires from rear cilinder, the sparkplugs from rear are soaking wet. So there is fuel.
Dinopaps is offline
post #6 of 12 (permalink) Unread 05-09-2019, 11:25 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
I remember a fellow had a bad running problem from one carb and took it back apart and found he had dropped out the small brass piece that sits in the throat below the needle. It would actually be the main jet outlet ,and the needle controls fuel rate when it drops down into it. See if that is missing on the trouble carb.
1983 750 Shadow
From the past=
post #7 of 12 (permalink) Unread 05-09-2019, 12:44 PM Thread Starter
You mean this part? If you enlarge the picture of the bowl, you can see it's there
Dinopaps is offline
post #8 of 12 (permalink) Unread 05-09-2019, 01:03 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
NO, look into the throat and see if there is a brass piece at the bottom where the needle slides into. I am not sure they all have a removable piece in there.
1983 750 Shadow
From the past=
post #9 of 12 (permalink) Unread 05-09-2019, 01:24 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I took a photo of my extra carbs to show the brass piece directly under the needle in the throat.
Maybe it would come out upward if it has a loose fit. ???
ID:	262524   Click image for larger version
1983 750 Shadow
From the past=
post #10 of 12 (permalink) Unread 05-09-2019, 02:32 PM Thread Starter
Thanks. On a vt1100 it's not removable but I'll check if it's still there. Thnx.
Dinopaps is offline
85 VT700 Wheels on a 85 Vt1100C Archangel12580 Technical Discussion 1 09-27-2014 06:06 PM
85 VT700 Wheels on a 85 Vt1100C Archangel12580 Member Introductions 0 09-27-2014 01:23 PM
Another charging problem 85 shadow vt1100c 5l1mm Technical Discussion 7 03-14-2012 12:28 PM
1997 vt1100c ----->1996 vt1100c forward controlls questio chrisola Technical Discussion 4 02-25-2010 04:09 PM
