Fastest and easiest way to install flash module? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 34 (permalink) Old 05-10-2019, 05:27 PM Thread Starter
Model: Shadow VT1100T
Year: 1999
On a 1999 Shadow VT1100T, what would be the fastest and easiest way to get to the brake wires that also had room to put the module?
Also, I only need one flasher for this bike, right?
Thanks in advance.
Gymjunkie is offline
post #2 of 34 (permalink) Old 05-10-2019, 05:35 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Check under the seat area for the wires. Many modules are very small with just a couple of wires to connect.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 34 (permalink) Old 05-10-2019, 08:39 PM
Steve C's Avatar
Model: Non Shadow 1982 Honda GL500I SilverWing Interstate, two cyl. transversive "twisted"twin
Year: 1996 VT1100C2 ACE Shadow
My 96 VT1100 ACE signal module is between the gas tank and the steering stem on the left from the seat.When I went to LED turn signals I had to go to this one.https://www.superbrightleds.com/more...asher/193/841/ .I had an issue with the single indicator light and went with this two diode kit.https://www.superbrightleds.com/more...iode-kit/1190/. A better diagram.
1996 VT1100C2 ACE Shadow,1982 Honda GL500I SilverWing,1980 AMF Roadmaster w/Minarelli V1 moped.."It's the journey not the destination" Ravens Roost Overlook milepost 10 Blue Ridge Parkway,Virginia
Steve C is offline
post #4 of 34 (permalink) Old 05-13-2019, 06:59 AM
Just installed a BackOff module yesterday on my 2004 Shadow Spirit VT1100. As Swifty noted, under the seat is the easiest location--one wire going to the brake lights.
MalibuX3 is offline
post #5 of 34 (permalink) Old 05-14-2019, 12:15 PM Thread Starter
Year: 1999
Thank you everyone for chiming in. Whenever I get the time to do this I may end up posting here again, but until then, thank you.
post #6 of 34 (permalink) Old 05-24-2019, 09:29 PM Thread Starter
Year: 1999
Found the wires while working on the oil in my air filter, I just am not sure what wires to splice into. How do I know which I should be doing this to?
post #7 of 34 (permalink) Old 05-24-2019, 11:01 PM
smilie's Avatar
Green/Yellow should be your brake light. I usually make pigtails at the plug rather than cut into the harness.
smilie is offline
post #8 of 34 (permalink) Old 05-25-2019, 12:30 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Probably separate the connector there for the yellow/green brake wire and insert your wires from the module.
And green wires are always ground in case you need a ground connection too.
1983 750 Shadow
From the past=
post #9 of 34 (permalink) Old 05-25-2019, 01:52 AM Thread Starter
Year: 1999
I'm used to sound systems in cars and am not entirely sure what you mean by "pigtails", and since Google showed me SEVERAL different things, would you mind clarifying for me a bit? If it's easier or even just makes a better connection...or just more professional..I am happy to do it the right way.
IIRC the flash module had 2 input wires and 2 output wires (the flashers are in the hard bags and can't check ATM). Would I simply attach the negative to any standard ground, or am I missing something?
EDIT: Looks like it's 2 in and 1 out
post #10 of 34 (permalink) Old 05-25-2019, 10:12 AM
Year: 2000
Let's recap what we know so far.
1) You want to install a "flash module" into your brake light circuit.
2) Since you never explained exactly what you meant, one poster thought you meant the flash module that controls your turn signals and posted a nice schematic and parts list.
3) You never responded to him, so we are left thinking he either solved your problem or his answer had nothing to do with your problem.
4) Another poster thought you may be referring to a "Back Off Flash Module" but your last post indicates this can't be correct either because you say you have 3 wires on your flash module, and the Back Off Module has 4 wires on it.
5) As it stands right now, you could actually be looking at a 3-wire turn signal flasher that the previous owner installed for something other than controlling brake lights.
6) The other possibility is that you might be under the impression that a 3-wire flasher relay can be used as a brake light modulator.
Until we get some answers as to what exactly you have, and what you are working with, and what you plan on installing (you asked earlier if one flasher would be sufficient), then we are going to continue going in circles as people try to 'guess' exactly what you are doing, and with what.
Chuck_Michigan is offline
Easiest way to remove decals off of a gas tank... Inferno Technical Discussion 2 03-30-2012 06:35 PM
Cheapest, easiest way of "loudening" a bit? qft Technical Discussion 13 10-16-2011 05:34 PM
Easiest way to make pipes louder jasonces3 Technical Discussion 18 10-29-2009 12:43 AM
Easiest way to change rear shocks iamsmiling Technical Discussion 6 06-02-2008 10:31 PM
where is my fuel filter and whats the easiest way to change xltmattuxx Technical Discussion 1 03-03-2007 12:43 PM
