Bike Issue - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 26 (permalink) Old 05-12-2019, 12:34 PM Thread Starter
Model: 750 Honda Shadow Ace
Year: 1998
Bike Issue
I recently changed my battery on my honda shadow 1998 750, when I changed the battery out and replaced with a new I did not get any power to the bike, I made sure the connections were correct and postive went to postive and negative went to negative. Any suggestions.
Rob Friedman is offline
post #2 of 26 (permalink) Old 05-12-2019, 02:33 PM
Did you charge the battery and check for correct voltage? It should be 13.2vdc for a new battery.
jpr1968 is offline
post #3 of 26 (permalink) Old 05-12-2019, 02:42 PM Thread Starter
Year: 1998
I checked everything the battery seems to be fine, I checked the fuses also, seems to be fine. could it be the control module box that is on top of the battery cover?
post #4 of 26 (permalink) Old 05-12-2019, 03:11 PM Thread Starter
Year: 1998
It was a brand new battery, could it be the control module it was working just fine a couple days ago. I know this is a dumb question but do i remove the control module before i put the new battery on?
post #5 of 26 (permalink) Old 05-12-2019, 03:23 PM
Often times the battery cable can become corroded inside the housing.
Also, many people put the big lug on the battery but forget the main bike power lug (that's not as thick as the other) onto the battery.
Check for a fusible link or main fuse. If you blew that, or broke the fusible link, you won't get power.
A good test is to disconnect the battery and then use an ohmmeter to check for continuity between the positive and negative cables.
Inferno is offline
post #6 of 26 (permalink) Old 05-12-2019, 04:14 PM Thread Starter
Year: 1998
where would i find the main bike power lug?
post #7 of 26 (permalink) Old 05-12-2019, 04:17 PM
It will either be a second connection at the battery or connected at the solenoid or the positive cable might split off.
Inferno is offline
post #8 of 26 (permalink) Old 05-12-2019, 05:13 PM
Year: 2000
Was the battery replaced because the old one was doing the same thing?
Chuck_Michigan is online now
post #9 of 26 (permalink) Old 05-12-2019, 05:47 PM Thread Starter
Year: 1998
no the battery was not doing the same thing, I replaced a 30 amp fuse but still no power...i checked all the connections
post #10 of 26 (permalink) Old 05-12-2019, 08:02 PM
Year: 2000
Could you expand on and explain in detail the history of the problem, along with this new development of having a 30 amp fuse blow? We don't have much to go on right now.
VT1100C Carb issue, Viabrations, Mirror issue Leathel Technical Discussion 7 01-22-2014 02:56 AM
bike not starting...choke issue? proto Technical Discussion 8 12-26-2012 08:19 AM
84 VT700 Issue upon issue CtJim Technical Discussion 3 11-26-2012 08:39 AM
New Bike Clearcoat Paint issue GregInMesa Technical Discussion 8 05-06-2012 06:15 PM
Took bike to shop for carb issue, no difference. txridr Technical Discussion 2 11-07-2009 04:27 PM
