What welder are people using? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 05-13-2019, 11:29 PM Thread Starter
For those of you who do your own frame work and other welding projects, what do you guys do?
I'm leaning towards OA but wanted other opinions
Sent from my moto z3 using Tapatalk
honkie45 is offline
post #2 of 12 (permalink) Old 05-13-2019, 11:59 PM
h13man's Avatar
Have a Clark 180 amp. mig. Harbor Freight haves a good selection of welders.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #3 of 12 (permalink) Old 05-14-2019, 12:08 AM
Ranma's Avatar
Model: VT700C
Year: 1984
I have mig, tig, stick and oxy acetylene, it depends on what you're welding.
When I built my trailer I used stick because per foot of weld, welding rod is dirt cheap compared to mig because shielding gas prices keep going up.
But for most motorcycle frame welding, and the majority of projects welding mild steel, mig is good.
Eventually the light always fails you.
Ranma is offline
post #4 of 12 (permalink) Old 05-14-2019, 05:47 AM
Kris Carr's Avatar
Model: VT500C
Year: 1984
I use a Millermatic 255 with 035 wire and the additional spool gun for aluminum. Its a fantastic welder but priced out of range for most hobbyists or weekend mechanics. I also have a smaller Hobart 145 with 023 wire that I use for thin sheet metal as the heat range is much lower than the miller. I dont think Id weld a frame with it though.
Kris Carr is online now
post #5 of 12 (permalink) Old 05-15-2019, 12:32 AM Thread Starter
Thanks for the replies everyone.
Come to find out when I was talking to my dad today I found out in a bunch of tools we got from my grandpa when he passed away years ago was an oxy acetylene setup so I'm gonna start practicing on that with just scrap pieces of metal to get use to the flow moving molten puddles.
I do have experience with OA but only brazing copper and brass
Thanks again
honkie45 is offline
post #6 of 12 (permalink) Old 05-15-2019, 01:49 PM
Ramie's Avatar
oxy acetylene is great for brazing and cutting but for the kind of welding your talking about you need mig
Ramie is offline
post #7 of 12 (permalink) Old 05-16-2019, 06:06 AM
Coop's Avatar
Mig, tig, stick, no Oxy Acetylene.
That's for fixing broken exhaust with a coat hanger or real brazing..... not structural repairs.
Harbor freight mug gun with coupon, get flux core, will do what you need and be cheap.
No Sig, someone whined and I lost it.. Crybaby....
Ride Bell By The Bride and Canyon
Retired bell by Old Dad
2 time BOTM winner
06 VTX Glide & 05 ST1300
Coop is offline
post #8 of 12 (permalink) Old 05-16-2019, 06:53 AM
vabrokenarrow's Avatar
Model: Spirit 750
Year: 2007
Flux core has less spatter than mig but runs hotter. I was a welder for 15 years. Tig is a stronger weld, but tends to be more costly. Keep in mind if you're welding, that it isn't just the weld but also the fit up. You want to make sure you weld to good metal and remove any paint from the heat affected area. If you notice porosity in your weld, you need to grind it out and re-weld it.
02 Goldwing GL1800 - "Gold"
07 Shadow Spirit 750
78 CB750K -went separate ways
84 KZ750 - deceased
04 Shadow Aero - passed Down
05 Shadow Aero -went separate ways
vabrokenarrow is offline
post #9 of 12 (permalink) Old 05-16-2019, 01:23 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I have a Harbor Freight 170 amp flux core unit and it works very well for the price.
I am still a lousy welder but I can at least melt metal together.
I need practice !
Solid core mig wire with gas does a very neat job, but flux core has the advantage of being able to work well outside in a breeze that could blow away the shielding gas bubble .
Just what I have read.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #10 of 12 (permalink) Old 05-16-2019, 06:05 PM
ButchA's Avatar
Welder? Um.... How about a 1963 Sears/Craftsman Arc Welder? -- it was my dad's from way back in the day. I have all his stuff, his welding shield, countless boxes of various welding rods, but no owners manual at all. My dad is no longer here (RIP, Pop... 1922 - 2002, 80 yrs old at his passing), and I've messed around with the old Arc Welder from time to time, and have no clue what I'm doing.
All I know is it is wickedly powerful, and I have to unplug the dryer from the outlet in the laundry room, plug in the gigantic 240v extension cord, then out the backdoor, and then plug the welder in from my back porch stoop. I've toyed with various plug-ins and amps and whatnot, and I was at least able to create a big burn mark down a scrap piece of metal (clamp/negative charge one one side - and the welding rod/stick (positive) ever so lightly touching the scrap metal, to where it made a massive spark, and a big strip of molten metal about 3" long.
How do you weld something with an old 1963 Arc Welder? I have no idea...
2007 Honda Shadow Aero 750
Visited states map via motorcycle: VA (home), MD, and NC.
Next states to visit: WV, PA, & NY
Ride bell by Old Dad (thank you! )
ButchA is online now
aluminum welder ? mike r Member Introductions 2 09-07-2013 07:50 AM
Challenge: grab your MIG welder RustDeamon Technical Discussion 4 08-10-2013 07:29 AM
will this welder work on bike frames? downinit25i Technical Discussion 20 06-11-2008 12:03 PM
