What does this plug do? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 7 (permalink) Old 05-15-2019, 05:07 PM Thread Starter
CoreyP's Avatar
Model: VT1100C
Year: 1999
This plug in the valve cover is leaking a little bit of oil, not sure what it's for?
I pretty much have to order everything over the internet for my Shadow, I'm sure the plug is cheap but shipped won't be. Can I just pull that out, put some gasket sealant around it and stick it back in? Actually I'm not sure how that comes out, looks like it just pry's out?
!999 VT1100C
CoreyP is online now
post #2 of 7 (permalink) Old 05-15-2019, 05:10 PM Thread Starter
CoreyP's Avatar
Model: VT1100C
Year: 1999
oops forgot pic.
!999 VT1100C
post #3 of 7 (permalink) Old 05-15-2019, 05:39 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Those are the cam bore plugs. And you have to take off the top of the engine to replace them properly. there is a ridge inside so they don't just slide out and back in.Mine leak worse than that and I just clean it off. Someday maybe a tear down.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #4 of 7 (permalink) Old 05-15-2019, 05:46 PM
Ranma's Avatar
Model: VT700C
Year: 1984
That is the plug for the end of the cam bore, it's easier and more economical to bore through and plug the hole, the two screw caps above that use and Allen wrench are for the rocker shafts.
Eventually the light always fails you.
Ranma is online now
post #5 of 7 (permalink) Old 05-15-2019, 08:06 PM
tjkoko's Avatar
Model: 2015 VT750C Aero
Year: 2015
Originally Posted by CoreyP View Post
This plug in the valve cover is leaking a little bit of oil.........
That is seepage surrounding the plug and it's totally negligible. Ignore it.
I am coming from an older Triumph Tiger background.
tjkoko is offline
post #6 of 7 (permalink) Old 05-15-2019, 08:18 PM
you can clean the area around the plastic plug with solvent then work some gasket sealer in behind the lip and let dry ! to do the real fix involves poping off the rocker cover and re-applying gasket sealer!
D-poland is offline
post #7 of 7 (permalink) Old 05-15-2019, 09:45 PM Thread Starter
CoreyP's Avatar
Model: VT1100C
Year: 1999
Sounds like a good idea. Taking the top off looks like it's not worth the effort to fix one plug.
!999 VT1100C
Where the Heck Does This Thing Plug In At!? JHoggSDCA Technical Discussion 4 07-13-2012 12:34 AM
What does this spark plug tell you jordan.harris Technical Discussion 7 07-05-2011 03:54 PM
The Type of Spark Plug Does Make a Difference! UPDATE page 2 rrounds Technical Discussion 26 03-26-2010 09:28 PM
Plug reading pictures.anyone ever seen this on a plug? xdshooter Technical Discussion 11 09-15-2008 11:52 PM
Drain plug or no drain plug, thats the question. Maraxion Technical Discussion 6 08-31-2008 08:49 AM
