Cooling issue - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 13 (permalink) Old 05-22-2019, 01:29 PM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
Originally Posted by swifty2014 View Post
The 1/8th inch movement of the main spring plate is not good. They are usually snug against the spring. The small plate is the return valve and should snap back when lifted with a finger nail.
Maybe try a new cap first.
And make sure of the pressure. If it says .9 (.9 BAR) on the top it is about 13 pounds. Many newer cars go up to 16 + pound caps and that would be too high.
Thanks @swifty2014 . The local old school shop didnt have a cap to my suprise, they usually have what i need. I did go ahead and get a new thermostat and tossed that in and toped off the radiator just for good measure. That did help. Got the temp just below the red and only got about 4-6 oz of coolant bubble out of the overflow vent. Did this in my garage on the center stand so only the bikes cooling system was controlling the temp.
Sent from my SM-G950U using Tapatalk
bigolepit is offline
post #12 of 13 (permalink) Old 05-22-2019, 01:35 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Here is one that may work. Just check the dimensions from your cap to see if it is the right design and size.
https://www.oreillyauto.com/detail/b...tor+cap&pos=14
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #13 of 13 (permalink) Old 05-22-2019, 01:40 PM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
Awsome. Ill check into that after work. $8 even if it dont solve the issue is no biggie.
Cooling Issue: 1992 VT1100 BamaBagz Technical Discussion 9 03-12-2014 08:39 AM
Cooling issue gordo2472003 General Bike Discussion 18 04-16-2012 07:33 PM
Issue: Cooling Fan In-Op shefinator Technical Discussion 4 07-24-2011 10:46 PM
Possible Cooling Issue? Ki Yote Technical Discussion 3 03-24-2011 08:01 AM
help please cooling fan issue crazy5269 Technical Discussion 2 05-31-2009 01:38 PM
