Oil in my air filter - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 05-24-2019, 03:04 PM Thread Starter
Model: Shadow VT1100T
Year: 1999
So today I had some time and decided to pull off the seat and look into where I could attach my brake light flasher but instead was greeted with a nice sized puddle of oil in my air filter and housing.
What could cause this? I don't even know where to begin trying to fix this as I've never had this issue before.
Spoke to the guy at the Honda shop and he told me the crankcase breather will sometimes spurt a bit of oil into the housing but said it shouldn't be much. This has enough oil in it that I need to go buy more because my bike is very low now.
ID:	262796   Click image for larger version
Gymjunkie is offline
post #2 of 15 (permalink) Old 05-24-2019, 06:52 PM
smilie's Avatar
Clean it out and don't worry about it. Theirs a drain tube at the bottom of your filter housing that should be periodically drained. I keep my oil level towards the top mark and after a long hard run it will put a little oil in the housing. Perfectly normal. If you run your oil level a little lower it's less apt to happen, if it bothers you.
smilie is offline
post #3 of 15 (permalink) Old 05-24-2019, 08:41 PM
With the VT750 crankcase foam vents to the air filter housing and then down. On the VT1100 In front of your air filter there should be a small rectangular plastic container that is used for any venting from the crankcase. One tube goes up to the box and one down. The tube going down is capped so if you look underneath and see a capped tube, put a container underneath, remove the cap and drain. There should be only a few drops.
It looks like maybe the tube, the container or both have become disconnected or full and you have vented to the air filter housing. You will need to clean that out and likely replace the air filter.
Typically I have no oil vented from the crankcase so this is an indication you are overfilling your oil causing it to foam and the foam is venting. Make sure you are doing the oil change and fill correctly ie bike upright rather than on side stand. For me the best practice is to measure how much oil I am putting in rather than relying on dipstick.
G.
gdb069 is offline
post #4 of 15 (permalink) Old 05-24-2019, 09:56 PM
smilie's Avatar
Oops. Didn't see he had an 1100!
smilie is offline
post #5 of 15 (permalink) Old 05-24-2019, 09:57 PM Thread Starter
Year: 1999
I was unable to find this small plastic container you were referring to but I will take another look tomorrow. Would it be outside/in front of the metal screen that's in front of the filter housing?
I gave my K&N a good couple washes, though it is stained. Think I may need to replace a K&N? I hope not.
Last time the oil was changed was by the techs at the Honda shop (since they were already doing a few other things for me) so I doubt it was overfilled, but it's possible. Pretty sure I checked afterwards anyway and all was good so I am not sure but I will keep an eye on it after I fill it up again.
post #6 of 15 (permalink) Old 05-24-2019, 10:00 PM Thread Starter
Year: 1999
Got it drained out, thank you. A bit dumb to say, but I've always wondered what that tube was for lol.
From what I have heard though it's perfectly normal for a small amount but there was a good 1.5"-2" of oil in the housing.
post #7 of 15 (permalink) Old 05-24-2019, 10:17 PM
smilie's Avatar
A little is normal. When's the last time you had it opened up? If you've never drained it, you could get an accumulation over time.
smilie is offline
post #8 of 15 (permalink) Old 05-25-2019, 12:35 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
There is a small liquid separator tank and that drain hose. It should have a plug in the end until time to drain and then re-plug.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #9 of 15 (permalink) Old 05-25-2019, 01:45 AM Thread Starter
Year: 1999
While it is absolutely possible since I literally just NOW learned about draining it (the joys of learning things the hard way), I can at least say that my oil was last changed by the Honda shop last year, which they most likely didn't even bother to check this part of it since it wasn't the issue I payed them for.
Honestly until now the only time I ever needed to check the air filter was when I first switched to K&N on my current bike, and before that when it wouldn't crank over on my old Nighthawk....which I found a damn mouse nest hahaha.
To be 100% upfront, I was raised by ALL women and didn't have the "training" some of you may have had. Instead of being a mechanical "genius", I can cook one hell of a damn good chicken breast lmao. I am of course trying to expand my knowledge so I do truly thank all of you for taking the time to educate my dumbass, and for being patient with me on all of this...and I ask that you all continue to show patience as I continue to learn.
I did find the plug with no issue and got it all drained and wiped out, it's actually something I have wondered about for quite sometime anyway (the hose I mean).
What is the importance of it being plugged at all times and why can't I just leave it open? I completely believe you, I just want to understand the reason why.
Other forums (for other vehicles) I have been on weren't so understanding when I asked "why" so I feel I need to clarify.
post #10 of 15 (permalink) Old 05-25-2019, 11:02 AM
Year: 2000
It might have a little bit of oil in it from extended highway driving, and when you pull up to a light and stop, it then drains on the ground right where your rear tire will be after you take off from the light. Now that could be quite the amusing sight as you hit that oil slick...
Chuck_Michigan is offline
No air filter cage in '83 VT750, what are my best options for an air filter? vlado Technical Discussion 7 05-09-2017 11:44 PM
took out my K&N air filter and noticed this tube of oil? jski711 Technical Discussion 7 09-12-2014 11:08 PM
Air Filter to OEM Sub Air Filter Element marka83 Technical Discussion 1 03-28-2014 07:33 AM
Honda air filter vs. Hiflo air filter Pastor Technical Discussion 3 06-04-2008 02:15 PM
