Overheating? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 05-25-2019, 11:23 AM Thread Starter
Overheating?
So, I finally finished putting my bike back together. 85 Honda Shadow vt700, upgraded carb jets, drilled out the baffles on the exhaust (hehe) some stripping and painting, and she runs GREAT!! However....it seems to run much hotter now, it’s not OVERheating, but the temp creeps up pretty high especially when idling. Ian there anything more I can do to help keep the temperature down??
TileNinja is offline
post #2 of 4 (permalink) Old 05-25-2019, 12:06 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Depends a lot on the temperature where you are. But the gauge will run up close to the red zone and then the fan will come on if all is working. Make sure the radiator is completely filled/burped.There is not air flow past the radiator sitting still.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 4 (permalink) Old 05-25-2019, 12:41 PM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
Another thing to look at is the condition of the fins on the radiator. As @swifty2014 says, there is no air flow past the radiator when sitting still. Pull the plastic shroud off the radiator (1 small bolt at bottom, two tangs at top) and inspect your radiator fins. You should be able to see through the fins easily, and not have an excessive number bent/flattened from stone damage due to the short front fender allowing gravel flinging backwards. Use high pressure hose to flush any mud or debris out of the fins. If you want, it's not a bad idea to have a spare fan thermostat (lower left corner of radiator, two-wire connector) that may kick in at a slightly lower temp, available online.
ShadowGeezer is offline
post #4 of 4 (permalink) Old 05-25-2019, 07:49 PM
smilie's Avatar
If the bike ran cooler before, I'm with @swifty2014 . It's the most common issue. Burp it and see. Also, you've changed jetting. If it's running leaner than before, it can also make it run hotter.
smilie is offline
Overheating juggalo080 Technical Discussion 16 08-17-2007 10:01 AM
Overheating-no fan kipmilam Technical Discussion 5 07-22-2007 04:35 PM
Help, I am overheating. scythefwd Technical Discussion 20 05-03-2007 10:24 PM
Overheating engine bill67 Technical Discussion 12 05-02-2007 10:47 AM
1983 vt750c overheating funky Technical Discussion 9 04-25-2007 01:02 AM
