Thermo switch - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 17 (permalink) Old 06-01-2019, 11:18 AM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
Originally Posted by swifty2014 View Post
The sensor on the thermostat housing is for the gauge only. The fan sensor is on the bottom area of the radiator.
You grounded the gauge sensor and the fan came on ??
No i grounded the negative wire off the fan to the frame with the ignition on. Reading my previous post i see i did word that poorly lol.
Sent from my SM-G950U using Tapatalk
bigolepit is offline
post #12 of 17 (permalink) Old 06-01-2019, 11:54 AM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
@swifty2014 i am glad you pointed that out because i was infact looking at the wrong sensor. The issue and cause is the im working on is the same as originally posted and i did the correct diagnostic procedure but..........i didnt realize the sensor i planned on pulling was the wrong sensor lol. The one in the thermostat housing is fine since my temp gauge works, the one you pointed out will be the bad one. Good looking out my friend. Hopefully i would have figured it out when what i ordered got here and it didnt match whay i was going to take off the bike lol.
post #13 of 17 (permalink) Old 06-01-2019, 12:14 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
You might wonder what the hell is this big thing???
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #14 of 17 (permalink) Old 06-01-2019, 02:08 PM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
No doupt. Since my last post the switch got delivered. Got it in the radiator and went ahead and cleaned the fins on the radiator while it is out. So should see some cooler temps running.
post #15 of 17 (permalink) Old 06-01-2019, 02:33 PM
I just looked in my Honda manual. The Thermoswitch has an o-ring seal so you shouldn't need any type of sealant on the threads. Sealant may actually interfer with grounding of the switch.
jpr1968 is offline
post #16 of 17 (permalink) Old 06-01-2019, 02:46 PM Thread Starter
bigolepit's Avatar
Model: VT700c
Year: 1984
Your right. It was pointed out that the switch i was looking at was not for the fan it was for the temp gauge lol. I was mistaken at the location and looked up the wrong one in the manual.
post #17 of 17 (permalink) Old 06-01-2019, 10:20 PM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
Replaced mine a while back; switch has an O-ring and tapered threads; didn't use any thread sealant, just turned it finger tight and 1/4 turn; no leaks.
ShadowGeezer is online now
