Clanking noise while running - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 06-04-2019, 03:54 PM Thread Starter
theskindiver's Avatar
Model: Honda Shadow Spirit 750
Year: 2003
Hi, I know it's hard to do any diagnosis through a text message, but I have a question...my always reliable Shadow 750 started making a clanking sound down low, between my feet, when I was pulled out in 1st gear. I thought it might be clutch, or slipping, but then is started happening while cruising.
My question is, I'm new to working on bikes and while it sounds like Tranny, is it reasonable to assume that if I take it apart, I'll be able to see what the problem is? Like a worn or bent part, etc? I obviously don't want to spend $2k on a shop...
Thanks for any ideas...
"Keep on Rocking in the Free World..."
theskindiver is offline
post #2 of 8 (permalink) Old 06-04-2019, 04:59 PM
I like to start with the simple things first.
What does the chain and the front sprocket look like?
As chains wear they move up on the sprocket with load, as the pitch effectively increases, worn sprocket teeth also kick the chain outwards.
Worn sprockets will get sharp pointy teeth and chains get longer 'til they break.
Things usually start making noise and at some point adjusting doesn't buy you time, things can get expensive quickly.
CSRoad is online now
post #3 of 8 (permalink) Old 06-04-2019, 06:46 PM
As CSRoad says, check to make sure your chain has the proper tension and that it's properly lubed.
jpr1968 is offline
post #4 of 8 (permalink) Old 06-05-2019, 06:07 PM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
You asked for ideas..if it's not your chain/sprockets, I had some "mystery clanking" on mine down low a while back.. Turned out to be one of my road footrests on my crash bars had lost a rubber damper. Hope yours turns out to be simple!
ShadowGeezer is offline
post #5 of 8 (permalink) Old 06-06-2019, 01:13 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Put it in low gear with the engine off and rock it back and forth hard, and see if anything make a noise like you hear.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #6 of 8 (permalink) Old 06-06-2019, 02:12 PM
Welcome @theskindiver
My first thought was Chain also, they tend to be noisey when in need of attention...
Adjust & lubricate the chain, SEE IF the noise goes away...
I`m Proud to Ride HONDA!!!
D
166,000+ on the clock
`98 VT750 A.C.E.
ABATE member 40+yrs.
www.ABATEGA.org
(DC District 13)
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Enjoying Life,D
"Captain D" is offline
post #7 of 8 (permalink) Old 06-19-2019, 02:07 PM Thread Starter
Year: 2003
Can anyone tell me how I can check if the chain is correct?
Many thanks
post #8 of 8 (permalink) Old 06-21-2019, 11:37 PM
smilie's Avatar
That search box at the upper right of your screen is your friend. Search " proper chain adjustment", make some popcorn, grab a beer, and enjoy a plethora of info.
smilie is offline
