Popping Out of 3rd Gear - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 17 (permalink) Old 06-08-2019, 11:46 AM Thread Starter
So, I finally got my project 86 VT1100 running decent enough to test ride it. Other than slight throttle issues it was great, and the sense of accomplishment was high.
Got it out on the main road, and while I was in 3rd gear I gave it some good throttle and it acted like it popped out of gear. When I let out the throttle it was back in gear without having to do anything.
My internet sleuthing leads me to think it is a bent shift fork. Does that sound about right? Is there any way to check before cranking open the crankcase?
Thanks all!
Agapedad is offline
post #2 of 17 (permalink) Old 06-08-2019, 02:45 PM
smilie's Avatar
You sure it wasn't clutch slippage?
smilie is offline
post #3 of 17 (permalink) Old 06-08-2019, 04:12 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I have heard other guys with an 1100 and 3rd gear caused a problem. But I thought it was a few years later than yours.
It may be a worn fork not holding it in position=- ?
Try snapping it in into 3rd gear to see if it can pop all the way in and stay there.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #4 of 17 (permalink) Old 06-08-2019, 04:50 PM Thread Starter
It stays in gear except when I get on the throttle, and pops back in when I let off throttle. Not sure I understand what you mean about popping it in and staying there.
ETA... The shifter doesn't move. It is like it goes into neutral, but engages again when I let off throttle.
Agapedad is offline
post #5 of 17 (permalink) Old 06-08-2019, 04:50 PM Thread Starter
Not sure about anything!
Agapedad is offline
post #6 of 17 (permalink) Old 06-08-2019, 07:37 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Possible wear on the lugs or dogs that actually transfer the power. If they are tapered from wear they wouldn't want to stay in .Here is what is happening inside the trans.
1983 750 Shadow
From the past=
post #7 of 17 (permalink) Old 06-08-2019, 08:03 PM
I'mKOHD's Avatar
Model: VT1100C2
Year: 1996
MY money is on clutch slippage,i would be inclined to think jumping in and out of gear would be accompanied with a ratcheting noise while it's not engaged.
My thoughts are; wrong oil (not motorcycle spec.) Incorrect adjustment, worn clutch.
[IMG][/IMG]
1996 Honda Shadow Ace 1100
I'mKOHD is offline
post #8 of 17 (permalink) Old 06-08-2019, 09:31 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Do a simple clutch test. Get up to about 40+ MPH in 4th gear. Pull the clutch and rev up to 4 or 5000 PM and drop the lever. It should pull the engine back down and lug if you keep about 1/2 throttle. If it flares and stays high the clutch can't grab ahold anymore.
1983 750 Shadow
From the past=
post #9 of 17 (permalink) Old 06-08-2019, 10:02 PM Thread Starter
Thanks guys. I'll start checking the clutch. I just had changed the oil before heading out. Put in Valvoline motorcycle 10w40.
Agapedad is offline
post #10 of 17 (permalink) Old 06-08-2019, 10:49 PM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
I'm inclined to lean toward a clutch issue. If it was happening in 2nd gear, it would be dropping into neutral, and that could be a bent (or installed backwards) shift fork or worn dogs on the inner portion of second gear itself. The 4th gear test is a great suggestion, since it is located on the opposite end of the tranny gears and should have much less chance of coming disengaged. Might be time for a set of clutch springs and plates. Keep in mind that if the ckutch was run before with non-motorcycle synthetic oil, the plates will have absorbed the slick stuff and need to be replaced since they'll never grab properly under load again.
ShadowGeezer is online now
