1984 honda shadow vt700c universal solenoid - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 20 (permalink) Old 06-11-2019, 04:58 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Here is the start circuit on our older bikes.
A starter solenoid is just a big heavy duty electric switch. It handles the big current while being activated by a small current. Any solenoid will do the same thing if it fits where you need it.
Name:	start solenoid.PNG
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #12 of 20 (permalink) Old 06-11-2019, 05:08 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
1983 750 Shadow
From the past=
post #13 of 20 (permalink) Old 06-12-2019, 07:51 AM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
I think you guys have it figured out from the solenoid wiring standpoint. I just came up with a bright idea on the possible function of the 2nd spark unit (that due to the tight-lipped and likely deceased Japanese engineers, probably can't be proved/disproved)...Bikes have a separate switch that actuates the starter. In other words, there is no unitized switch that both controls the ignition and accessories. That said, there is no ignition switch position that kills the accessories while cranking, so whatever is "on", is "on" during cranking the bike. My theory is that since the second spark unit is in parallel with the first unit, you guys are right on with the similar function to the bypass circuit on the old coil resistors. My guess is that the second spark unit is a second set of capacitors that gets brought in as a boosting capacitor discharge unit to boost voltage to the plugs during the load on the battery during cranking. It may even be a "shower of sparks" CDI to aid in cold starts. My guess is that in later models, they eliminated the 2nd unit by increasing the capacitance in the primary units, running a " hotter" ignition full-time. Just my $.02..
ShadowGeezer is online now
post #14 of 20 (permalink) Old 06-12-2019, 11:53 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
So many possibilities. But these older ignitions are called Transistor Ignition systems that replaced the old basic point systems. They used a power transistor to ground the coil negative as the old points used to do.
Then later years came out with an actual CDI system and the service manuals for those show a voltage to the coils over 100 + volts. That was new to me too.
1983 750 Shadow
From the past=
post #15 of 20 (permalink) Old 06-12-2019, 01:08 PM
Year: 2000
Remember back in the old days when on any given day in any given parking lot or side street you could watch some car with a dead battery getting push started by their friend in another car?
Then along came alternators and ruined everything.
Chuck_Michigan is offline
post #16 of 20 (permalink) Old 06-12-2019, 07:19 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Yes those were the good old days. Automatic transmissions had a rear pump so you could get it up to about 35 MPH and it would turn the engine to start.
And the good old steel bumpers that when you rear ended someone your front bumper got hooked under their rear bumper , so you would see guys jumping up and down on the bumper to free them. Fun Times !
I saw this picture of a bumper mounted trailer hitch and had a good laugh. Built like a tank.
Name:	1950 Dodge Meadowbrook.jpg
1983 750 Shadow
From the past=
post #17 of 20 (permalink) Old 06-12-2019, 11:27 PM
Model: VT700
Year: 1985
And the body work was 8ga. and 10ga. "sheet metal" that did a wonderful job of transferring collision energy directly to the passengers.. And "souped up" ignitions were dual-point dual-coil setups to keep up with the demands of balanced and blueprinted engines that would turn (Wow!) 7,000 rpm to move those lead sleds...
post #18 of 20 (permalink) Old 06-15-2019, 03:17 AM
shado#9's Avatar
ok perhaps late or off track a bit But you can disassemble the new solenoid /relay and re use your old harness ...I did ... I have 86 vt1100 and the start relay was not an exact match wire wise ...
so after purchase from ebay I disassembled the top of mine and new and did the swap ...
worked like a charm....good luck
shado#9 is offline
post #19 of 20 (permalink) Old 06-15-2019, 09:13 AM
Big Shrek's Avatar
Model: VT500C
Year: 1983
now THAT is something you should have taken pics of!! A few helpful photos to assist those of us who've never seen one dissassembled!!
Ride paranoid. Don't let anything distract you.
Keep the paint side up, wear the lid & leathers.
Big Shrek is offline
post #20 of 20 (permalink) Old 06-15-2019, 10:51 AM Thread Starter
Model: VT 700
Year: 1984
I found a NOS solenoid. Should be here next week. Having some other odd electrical problems. Going to create a new thread for that.
jmsanch is offline
