2003 Honda sabre 2nd gear - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 06-12-2019, 03:42 PM Thread Starter
venturai's Avatar
Model: sabre 1100c2
Year: 2003
When I go into second gear it doesn't want to some times it grinds the gears but I have found out that if I go into neutral and then go into 2nd it does it less I replaced the clutch about 6,000 miles ago with a Bennett I believe and it never stopped maybe my clutch cable but the rest of the gears are fine any ideas
you can't make the perfect girlfriend but you can make the perfect bike
venturai is online now
post #2 of 12 (permalink) Old 06-12-2019, 03:44 PM Thread Starter
venturai's Avatar
Model: sabre 1100c2
Year: 2003
Bike has about 16,000 miles
post #3 of 12 (permalink) Old 06-12-2019, 03:45 PM Thread Starter
venturai's Avatar
Model: sabre 1100c2
Year: 2003
Barnett clutch
post #4 of 12 (permalink) Old 06-12-2019, 08:35 PM
The first thing I'd check is the clutch free play at the lever is as shown in the Owner's Manual.
Given the situation I'd try it adjusted at the tighter end of the specified range.
Hopefully this will help.
CSRoad is offline
post #5 of 12 (permalink) Old 06-12-2019, 08:43 PM Thread Starter
venturai's Avatar
Model: sabre 1100c2
Year: 2003
It's all the way out
post #6 of 12 (permalink) Old 06-12-2019, 09:59 PM
CoreyP's Avatar
Model: VT1100C
Year: 1999
You can shift up without using the clutch so I don't think that is where the problem is. Have you tried shifting up without the clutch? Won't hurt your bike. Going down is much harder. Here's a video about it.
This is kind of weird. I would take the clutch out of the equation and see what happens.
!999 VT1100C
CoreyP is online now
post #7 of 12 (permalink) Old 06-13-2019, 12:28 AM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
Besides clutchless up shifting, you might also try double shifting from 1st through 2nd directly to 3rd using the clutch. Also try downshifting from 3rd to 2nd using the clutch. See what happens in both cases. What happens may help you to identify either a bent/worn 2nd gear shift fork, or worn engagement dogs on your 2nd gear itself.
ShadowGeezer is offline
post #8 of 12 (permalink) Old 06-13-2019, 03:36 PM Thread Starter
venturai's Avatar
Model: sabre 1100c2
Year: 2003
If I even try to go up it grinds some times it's just when popping it up and i get to the second gear doesn't do it to neutral and when i down shift its fine
post #9 of 12 (permalink) Old 06-13-2019, 09:58 PM
Model: VT700
Year: 1985
I'm shooting in the dark here, cuz I don't have an exploded view of the 1100 Sabre shift linkage. But here's where I would start looking. Sounds like you had this issue even before installing the Barnett clutch. From the sound of things, you are only having issues when you up shift to second, but not downshift or going down to neutral. I would start by pulling the clutch and inspecting the end of the shift drum with the shift linkage intact. It sounds to me like the problem is only occurring when the drum is rotating in the up shift direction and only when up shifting into second. But the problem is not occurring when the shift drum is rotating the opposite direction third to second, or second to neutral. To me this would eliminate the 2nd gear engagement dogs and the shift fork (both internal) as the problem. It sounds to me like there may be a wear on the external portion of the drum at the position where the drum is moving neutral to second/second to neutral, so the ratcheting mechanism isn't quite biting enough to upshift through neutral to second. If it is there, that would be the good news. If it is not, the next possibility I would see would be a wear issue on the shift drum chamfer where the 2nd gear shift fork rides, or possible wear on the 2nd gear shift fork itself; if it is either of these, it's a problem requiring a major tear down. Hope you can get it resolved!
post #10 of 12 (permalink) Old 06-13-2019, 10:09 PM
Model: VT700
Year: 1985
One other thing to try before going into the case, if you haven't already tried it. Get up into third, downshift into second, then accelerate in second and see if it stays in gear. If it does, then my next guess would be the preceding post.
