Idle speed Problem. - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 13 (permalink) Old 06-26-2019, 07:42 PM Thread Starter
BareBones's Avatar
Idle speed Problem.
I have a 1986 Honda Shadow VT500c. I noticed that the idle speed on my bike seems to be around 2000. I tried adjusting this with the idle screw but it was all the way out and not touching the throttle. I threaded the screw in and seemed to make my rpms jump up very high so I quickly undid the screw backing it all the way out. What could be causing this. Also I've noticed that when I shift to 1st gear from idle or 2nd it makes a audible clunk sound. It doesn't do this every time but pretty frequently. I will provide a pic of my rpms at idle.
BareBones is online now
post #2 of 13 (permalink) Old 06-26-2019, 08:57 PM
Kris Carr's Avatar
Model: VT500C
Year: 1984
Is the choke moving freely? On these carbs "choke" is a bit of a misnomer, they actually use an enricher. The choke cable moves small pistons in enrichment ports in the carb. If one or both of these pistons arent fully closing it could cause a high idle situation
Kris Carr is offline
post #3 of 13 (permalink) Old 06-26-2019, 09:03 PM
mmnewcomb's Avatar
Check your throttle stop screw. Your throttle might not be fully closing when you release it.
1994 Shadow VT1100C Rat Bobber Project
mmnewcomb is offline
post #4 of 13 (permalink) Old 06-26-2019, 09:57 PM
Ramie's Avatar
Also could be your throttle cables. Make sure you have about 1/4 inch of play on your throttle.
Ramie is offline
post #5 of 13 (permalink) Old 06-27-2019, 06:33 AM
mmnewcomb's Avatar
After re-reading your post, I realize my last reply was talking about the same thing. I've always called it the throttle stop but that's incorrect. Have you checked the A/F mixture screws on your carbs? They could be all out of wack. You'll want to turn them all the way in until they are lightly seated (don't go any further or you'll damage the needles) and then bring them out 2 to 2 and 1/2 turns and start there, or if you have a Haynes manual check what that says for your initial settings and then adjust from there.
post #6 of 13 (permalink) Old 06-27-2019, 03:11 PM Thread Starter
BareBones's Avatar
Thank you all for the suggestions. I am going to try the choke adjustment first. I will keep you updated.
post #7 of 13 (permalink) Old 06-27-2019, 07:39 PM
smilie's Avatar
Also make sure you don't have a leak in your air intake.
smilie is offline
post #8 of 13 (permalink) Old 06-29-2019, 03:50 PM Thread Starter
BareBones's Avatar
So after adjusting the left side choke I then moved on to the right side one. After unscrewing from the carbs I noticed it was missing the spring. Could this be the reason I am getting a high idle. My theory is that without the spring it is causing the valve to not fully close allowing air to get in.
Ride till ya can't no more
post #9 of 13 (permalink) Old 06-30-2019, 04:56 PM Thread Starter
BareBones's Avatar
Here is a picture of what I found.
post #10 of 13 (permalink) Old 06-30-2019, 05:58 PM
Kris Carr's Avatar
Model: VT500C
Year: 1984
I think that would do it
