LED Flasher fix ,,,,,,,,,,,,,,,,,,,,,,,,, - Page 3 - Honda Shadow Forums : Shadow Motorcycle Forum
post #21 of 37 (permalink) Old 04-26-2017, 05:30 PM
I only have the LED for brake light not the turn signals......
Clint.dunnet is offline
post #22 of 37 (permalink) Old 04-18-2019, 06:34 PM
So... I have an issue. The relay I removed from the bike has BLE on it. Not XLP. The two wire relay 8 bought doesn't have any letters on it, just a red and a black wire going to a connector, which oddly enough fits directly 9nto the bike. I thought by some divine chance, that it might be plug and play. So I hooked it up, no blinkers. Tried turning on the bike aaaand blew the main fuse. Upon checking, it looks like the blinker fuse went too. Do now I'm working on replacing the fuse. Does anyone know which wires should go where here? I have an 03 vt1100c2. With the relay under the tank by the tree.
Brian Brockhouse is offline
post #23 of 37 (permalink) Old 04-18-2019, 06:52 PM
smilie's Avatar
I just installed a 2-wire electronic flasher on my bike to remedy hyperflash when I switched to LEDs up front. Let me take off the side cover when I go to the shop in a bit. Mine was plug and play but do recall mention of switching the wires if they weren't in the proper position in the plug.
smilie is offline
post #24 of 37 (permalink) Old 04-18-2019, 07:03 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
The original code may be for Battery, Load and Earth. - ?
The white/green wire is power into the relay than the grey wire goes out to the switch and lights.
Try to hook white/green to the red terminal. And the grey to the black.
The green wires are always ground (earth).
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #25 of 37 (permalink) Old 04-18-2019, 08:22 PM
smilie's Avatar
^What @swifty2014 said. Just checked my bike.
smilie is offline
post #26 of 37 (permalink) Old 04-18-2019, 08:35 PM
Awesome. Thanks
post #27 of 37 (permalink) Old 04-18-2019, 09:03 PM
Alright! So, here I feel stupid. The plug and play was actually the right fix. When I reinstalled the rear fender, the left rear turn signal, orange wire, got loose and grounded out. Blowing the fuse. When I replaced the fuse and ensured the wire was right I was getting nothing but hazards. All flash. Except the left rear. So I rechecked the wires, put the wire back where it goes and everything is right in the world again. Thanks so much for your support guys.
post #28 of 37 (permalink) Old 04-19-2019, 12:17 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
We love it when a plan comes together.
1983 750 Shadow
From the past=
post #29 of 37 (permalink) Old 04-20-2019, 10:44 AM
Model: ACE 1100
Year: 1998
I decided to add a running light bar to my ACE 1100. It's all LED, everything functioned fine (running lights and signals) with my factory signals in the back. I decided that I didn't like having different signal housings on the front and rear, so I bought matching LED signals for the rear. I installed an EL12, 12V (White/green) to X, Lights (Grey) to L. The rear signals I purchased are 3 wire for runnings lights and signals but the factory harness is only for signals in the rear. I pulled the tank and tapped into the running light feeds in the electrical box up front to five myself running lights in the back. The running lights seem to function just fine. When I switch on my signal, it seems to disengage the running lights and engage the signal circuit, but it's not engaging the flasher, the lights just stay on. I thought maybe I thought maybe I screwed up the flasher or perhaps had a defective unit and even took it back to AutoZone for a new one. I have tried removing the indicator bulb on the tree, but it doesn't change anything.
Any sage words of wisdom?
The video still has the indicators on the tree installed, I removed them after I took the video.
nuts-n-bolts is offline
post #30 of 37 (permalink) Old 04-20-2019, 11:20 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Not sure why it is dimming the lights when you turn on the turn signal. Maybe disconnect the rear running light wires and try it. You could just tap into the tail light wiring for the running lights in the rear to keep it simple. LEDs won't overload a circuit.
But just noticed the amber lenses in the rear. They have to be red lenses. No amber lights showing in the rear that stay on. Just like on a car.
1983 750 Shadow
From the past=
LED Flasher Relay?? buckmaster299 Technical Discussion 2 11-07-2013 08:22 PM
led flasher mlr Technical Discussion 6 09-28-2013 09:23 PM
can't find my clymers, where is the flasher fuse and flasher unit? RocksBlues Technical Discussion 6 07-13-2013 06:28 PM
Plug N Play LED Flasher For Phantom deekortiz3 General Bike Discussion 5 12-31-2012 12:25 AM
Cheap fix for a non-oem flasher relay unit 1983 vt750 stlouisaaron Technical Discussion 6 06-26-2011 04:05 PM
