choke ajustment please help.. - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 05-25-2010, 05:50 PM Thread Starter
with choke pulled out bike starts and idles fine but once It is warm in not able to push choke all the way in or the bike dies. Dos anybody know how to fix. [/b][/code]
PhilMac23 is offline
post #2 of 8 (permalink) Old 05-25-2010, 06:48 PM
It's not likely a problem with your choke -- it seems to be working as it should.
You're getting too much air or not enough fuel.
Make sure the air cleaner is installed
Make sure the carb boots are OK
Add the recommended dosage of fuel treatment (people seem to like Seafoam or Berryman's B12) to your tank and run it through
Clean your carbs and check your float level
scottrhodes13 is offline
post #3 of 8 (permalink) Old 05-25-2010, 07:27 PM Thread Starter
Do you know how to adjust the fuel/air on a shadow 750. I've tried everything you mentioned. I'm running b-12 through tank now. I've been driving with 1/2 choke and everything is fine till 10 min in and choke will work its way all the way in and the bike will stall while driving..
post #4 of 8 (permalink) Old 05-25-2010, 07:45 PM
I don't know much about carbs but your air/fuel mix is off. Thats all I got.
simpleman77 is offline
post #5 of 8 (permalink) Old 05-25-2010, 09:47 PM
PhilMac23, what year and model of motorcycle do you have?
landon is offline
post #6 of 8 (permalink) Old 05-26-2010, 06:26 AM Thread Starter
Its a 04 shadow spirit 750VT w/ 15000 miles.
post #7 of 8 (permalink) Old 05-26-2010, 09:43 AM
Back the the first principle of troubleshooting:
Try NOT to overlook the obvious !!
Sounds to me like you might have two very simple problems; idle stop screw missing or not set right......assuming it is stalling out just because the idle speed drops too low......and you can keep it running at a proper idle speed just by cracking the throttle a bit with the choke off...AND the "drag" adjustment on the choke needs a little tweek.
You may have a low speed jet problem but I'd think it would run rough as the speed drops if that was the case. The cleaner may help.
Easy Rider 2 is offline
post #8 of 8 (permalink) Old 05-26-2010, 10:12 AM Thread Starter
Thanks Easy Rider 2
I'm going to try ajustng them to fix problem. I'd hate to find out that a little problem stopped me from riding to Rolling Thunder...thanks again for reply..
please please please help me tc862011 Technical Discussion 22 05-03-2014 10:34 PM
Carb ajustment Nurseman1313 Mountain Riders 3 08-22-2012 11:13 AM
idle speed ajustment snowrider Technical Discussion 4 08-17-2010 09:23 PM
Rear shock ajustment Bowlbug Technical Discussion 8 10-13-2007 01:43 PM
I need help....please please please.... bweiner10 Technical Discussion 6 04-21-2007 08:54 PM
