1992 VT1100C : No Light, No Tick, No Crank, No Start - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 6 (permalink) Old 05-28-2010, 10:05 PM Thread Starter
Howdy People~ Crazy Problem...
Last time I rode this bike was in September 09 and the battery was getting weak (has to be at least 5 years old) and was just barely able to turn over to start. This month I purchased a new battery (charged it completely : checked with meter 12V). Now...I got nothing working.
Bike doesn't turn-over or even click, no headlight (any lights for that matter). Checked the Fuses in the box and the inline main battery fuse. I attached an extra ground to the bike from the - battery (to test). Nothing...Nodda.
All the wires and leads look clean and connected.
I'm Toast<!> Anyone have any ideas???
[ThnX ]
reagan is offline
post #2 of 6 (permalink) Old 05-28-2010, 10:49 PM
Eldorado's Avatar
Model: Sabre
Year: 2002
Did you check the kill switch, just in case it was put in the off position....
http://s33.photobucket.com/user/eldo....jpg.html?o=11
"John" 2002 Sabre
Patriot Guard Rider
Eldorado is offline
post #3 of 6 (permalink) Old 05-28-2010, 11:04 PM
Been there, done that, definitely a "here's your sign" moment.
Check the voltage to the starter solenoid, you need to find where the electricity "stops". Start at the positive battery terminal and work your way out from there.
txironhead is offline
post #4 of 6 (permalink) Old 05-29-2010, 12:20 AM Thread Starter
Sure enough did...Although it wouldn't be the first time I over-looked that. Thnx.
reagan is offline
post #5 of 6 (permalink) Old 05-29-2010, 12:32 AM Thread Starter
Good Idea, I haven't cheched the solenoid :: Q? If the solenoid is bad - Could that stop all the gauges and lights from working?
reagan is offline
post #6 of 6 (permalink) Old 05-29-2010, 01:07 AM
Not sure how it is on your bike, but on mine the solenoid is a combination of starter relay, main wiring harness connection and master fuse, so it's possible something there is screwed up or corroded.
Single Pin Crank CDI with Double Pin Crank Motor? halifax Technical Discussion 26 06-17-2012 05:31 PM
Tick tick sound 1999 1100ACE Brooksie Technical Discussion 7 03-25-2012 01:20 PM
single pin crank - dual pin crank. bananabenda Technical Discussion 4 07-05-2008 07:19 PM
Tick Tick Tick GREGMCKEE Technical Discussion 3 05-12-2008 09:10 PM
Tick, tick, tick Len Klajda Technical Discussion 1 10-13-2007 03:55 PM
