Post 3: LED Bulb Replacement - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 9 (permalink) Old 04-21-2019, 10:45 AM Thread Starter
Model: Aero ABS.
Year: 2014
As a new rider I want to do everything I can to make myself more visible to the oblivious car drivers around here. It may be overkill, but I bought a Hi-Viz helmet and jacket. I want to investigate adding LED lights to a 2014 Aero to make them brighter. Are there replacement bulbs that pop in without having to make wiring changes? I saw something about adding "diodes". Are light bars worth adding? Do light bars use LEDs?
DrSteve is offline
post #2 of 9 (permalink) Old 04-21-2019, 02:27 PM
Model: VT750C2B AC - California Shadow Phantom
Year: 2015
I'm going through all of that RIGHT NOW.
I can tell you no real reliable brand makes replacement LED bulbs for the signals/parking lights. Sylvania's the only name brand I'd trust. Their LED bulbs are nice and bright with one HUGE problem for us: they project backwards. The turn & parking lights have no reflectors bouncing the light back out - meaning putting that pricey bright LED bulb in there will effectively make your light dimmer.
The brake lamp has a reflector - I suggest swapping that one out.
I'm in the middle of installing two 6" LED light bars on the bike. Custom mounts/making my own wiring.
So no. Quick replacements are expensive/rare - But that means it's time to roll up those sleeves and do it ourselves! More fun that way.
SwiftShock is offline
post #3 of 9 (permalink) Old 04-21-2019, 03:04 PM
smurfy71's Avatar
Google the Opt7 bulb. Direct swap for the stock bulb.
Light bars are good, added lights are always good.
I just put some LED switchback bulbs in my front signal, they are white as running lights, then flash amber for turn signals. I bought a plug and play relay that prevents hyper flash.
On my VTX I have a Daymaker headlight, I’m sure it can be done on a Shadow with some $ and mods.
Sitting on my VTX making Vroom Vroom noises.
https://www.hondashadow.net/forum/me...e71386-vtx.jpg
2006 Shadow Aero 750, "Audrey" - Jan 2017 BOTM - Sold Oct 2018
2008 VTX 1300T - Oct 2018 Co-BOTM
smurfy71 is offline
post #4 of 9 (permalink) Old 04-21-2019, 09:47 PM Thread Starter
Model: Aero ABS.
Year: 2014
Thanks for the info.
I was just reading the VA inspection requirements and modifying the lights is apparently not allowed. They do say that LED bulbs can be used.
DrSteve is offline
post #5 of 9 (permalink) Old 04-22-2019, 01:01 PM
Ramie's Avatar
Welcome, add a couple of these lower down on each side and they'll see you coming.
https://www.superbrightleds.com/more...0-lumens/1386/
Ramie is offline
post #6 of 9 (permalink) Old 04-22-2019, 10:23 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Welcome.
I got a couple like these and mounted them down on a highway bar about front axle high. I read where the triangle shape of the front lights really helps get drivers attention instead of the normal 3 across driving lights on most bikes. Cheap enough and bright!
https://www.ebay.com/itm/2pcs-CREE-U...EAAOSwn-tZL3AV
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #7 of 9 (permalink) Old 04-23-2019, 10:48 AM
Model: VT600C
Year: 1993
Does the OPT7 require any additional mods or is it plug n play? I'm thinking about getting it for my Shadow.
1993 Shadow VT600C
2001 Suzuki Kat 750
DieselDoctor is offline
post #8 of 9 (permalink) Old 04-25-2019, 11:25 AM
smurfy71's Avatar
Plug and Play
smurfy71 is offline
post #9 of 9 (permalink) Old 04-25-2019, 02:50 PM
I have LED called Nighteye
https://www.ebay.de/i/132109395184?chn=ps
they are quite good, maybe not the best around, but much better than the old bulbs, and they fit into the original housing.
They are worth the money, and I can see better in the dark and cars can see me. When the housing is adjusted correctly, they don't glare.
You can't compare them with the older LED lamps, the nighteye are good qualit LEDs.
ShadowFlo is offline
LED Lic Plate Bulb Replacment Giz Technical Discussion 0 06-03-2009 02:19 AM
LED license plate bulb brock29609 General Bike Discussion 9 01-10-2009 04:56 PM
LED light bulb for replacement bulb? jmitchell99 Technical Discussion 14 09-30-2008 09:37 PM
Results with LED bulb replacements for stop and tail lights? iamsmiling Technical Discussion 3 09-26-2007 07:31 AM
LED replacement bulb for Brake Light sandonn Technical Discussion 11 05-18-2007 09:52 PM
You may post new threads
You may post replies
