Vibrations problems. Help ! - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 05-17-2019, 12:28 PM Thread Starter
Exclamation Vibrations problems. Help !
hi !
SO, my main reason I found you guys, is because I have a main issue. My motocycle vibrate ALOT when I drive.
It does so much, that i cannot feel my hands afterwards. They feels like I have millions of ants in them.
We (my bf and me) are not sure what the problem is, and when I ask at a garage, he said it was age.
But we all know their must be a reason for it.
It like parkinson. It do not arrive because of age.... I won't go into it, but it's a degenerative thing in the brain otherwise every elderly would have parkinson .....!
Please help me (I'm literally doing puppy eyes).
Thanks !
andy1313 is offline
post #2 of 8 (permalink) Old 05-17-2019, 05:22 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Welcome to the forum. Tell what model you have and that may help .
These Shadows don't have rubber engine mounts. They are bolted solid, So all the engine vibe will transfer into the frame. If you have a newer model they have rubber mounted handlebars.
I have a 1983 750 and the handlebars are solid. So I get numb fingers after a while also.
There are handlebars weights you can put into the ends to help counter balance the vibe some what.
Depending on the model you can 7/8 or 1 inch bars.
https://www.ebay.com/itm/22mm-7-8inc...JOKFBqZfQcV0kg
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 8 (permalink) Old 05-17-2019, 05:43 PM
ShadowGeezer's Avatar
Model: VT700
Year: 1985
Assuming your engine mounting bolts are all tight and none missing, you can mitigate the effect of a lot of vibration by making sure you don't hold a "death grip" on your bars. Allow your hands to relax a bit while you're cruising, even extending your fingers out over your clutch and brake handles with occasional stretches and curls. There are also some good quality quick-release throttle lock cruise controls that are aftermarket that you can engage for short periods of time on longer trips that will allow you to ride one-handed and alternate hands.
ShadowGeezer is online now
post #4 of 8 (permalink) Old 05-17-2019, 08:19 PM
83 VT500 The engine was shared with the Ascot. Not known to have excessive vibration with some at about 4000 RPM. I would suggest making sure tires are good and inflated correctly and a good tune up. Perhaps check valve clearances.
G.
gdb069 is offline
post #5 of 8 (permalink) Old 05-17-2019, 09:50 PM
Ranma's Avatar
Model: VT700C
Year: 1984
My 84 700 still has the stock buzz dampers in the bars, they are about nine to ten inches long with large rubber rings on each end and they just slip in the end of the handlebars and then put the grips on. Have your bars been changed or the dampers been lost. According to hondapartshouse they are still available for around $15 each.
The rubbers are separate of course.
Eventually the light always fails you.
Ranma is offline
post #6 of 8 (permalink) Old 05-17-2019, 11:24 PM
Is the buzz related to a certain engine RPM range?
A certain amount of harmonic vibration is normal in most engine designs.
If so just running with a higher or lower engine speed may help.
There are some relatively cheap handlebar grips out there that may help.
A quick way to try if that is heading in the right direction maybe something like this:
https://www.amazon.com/Grab-Grips-Gr.../dp/B000WJAH5M
Check the sizing.
With my bike a VT750 ACE, a bike that vibrates worse than the VT500 due to crank design.
I chased down similar symptoms, trying various things.
I found in my case, the stock handlebars and the nerves or blood flow in my wrists didn't get along on longer rides and my hands would start to go numb and if they did I'd have a "pins and needles" sensation as they returned to normal.
I changed the angle of my handlebars in the clamps and noticed some relief, but not a complete solution, but it pointed me in the direction for my solution.
After some experimentation, sitting in the shed mocking up various positions with bicycle handlebars, electrical conduit, zip ties and duct tape to find where my hands felt most comfortable. I then took measurements and went handlebar hunting online.
I ended up switching to a different lower handlebar type with a different wrist angle and the problem went away.
CSRoad is offline
post #7 of 8 (permalink) Old 05-18-2019, 12:52 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
There are these foam grip puppies to help also.
https://www.amazon.com/Grip-Puppy-Co...e&sr=1-1-spell
1983 750 Shadow
From the past=
post #8 of 8 (permalink) Old 05-18-2019, 11:42 AM
Kris Carr's Avatar
Model: VT500C
Year: 1984
my 500 developed a vibration and a funny unstable feeling in corners that I thought was due to me lowering it. One day I was taking a smoke break and snapping some pics of my bike when I noticed light coming through the frame where it had no business being. Turned out there was two bolts missing! Click image for larger version
ID:	262660 I have no clue how they came out or when. I had never touched them. Once I bolted the frame back together It felt like a whole new bike. You might want to check and make sure everything is tight.
Kris Carr is offline
shadow 1100 - shocks, rejet, vibrations, and slippery ride? rkneeshaw Technical Discussion 3 06-24-2008 10:16 AM
Good(!!!) Vibrations! Skia (Shadow in Greek) General Bike Discussion 17 06-19-2008 10:40 AM
Street Vibrations ashadowrider General Bike Discussion 8 09-25-2007 01:16 AM
Feelin' them not so good vibrations on a VLX cyranodb Technical Discussion 4 09-01-2007 11:20 PM
You may post new threads
You may post replies
