Clanking noise while running - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 05-23-2019, 02:42 PM Thread Starter
theskindiver's Avatar
Model: Honda Shadow Spirit 750
Year: 2003
Hi,
I have a 2003 Honda Shadow 750, and about a week ago, I started getting a clanking noise when I was accelerating in 1st gear coming from the bottom of the bike, basically between my feet. It sounds like someone is putting a ruler into a running fan and feels like it partially disengages from gear. At first I thought it might be clutch, but it started happening while just cruising along in any gear. My guess is Tranny, but not sure...
Many thanks for any ideas or comments.
theskindiver is offline
post #2 of 4 (permalink) Old 05-23-2019, 04:50 PM
Super Moderator
Phil's Avatar
Model: 750 ACE Dlx
Year: 1998
Does the engine make the noise when you're at a stand still if you rev the engine in neutral?
Also, have you inspected the drive chain as well as both the front (drive) sprocket and the rear (driven) sprocket? Could also be the rear wheel damper which helps absorb any of that herky/jerky feel from the chain drive? Without actually hearing the sound though it's hard to tell....
Good luck,
Phil
1998 VT-750 ACE Deluxe
Sterling Heights, Michigan
Phil is online now
post #3 of 4 (permalink) Old 05-24-2019, 05:18 PM
Model: 750 ace
Year: 2002
Put your hand on the water pump and see if that's where the noise is coming from. I just posted about this same noise
staticx is offline
post #4 of 4 (permalink) Old 05-24-2019, 07:41 PM Thread Starter
Year: 2003
Thank you, I know it's hard without hearing it. No, it doesn't make any noise when it's not running. I will ck the water pump, but it really sounds like it's coming from between my feet...I'm fearing tranny...
Clanking noise from left side. zoko230 Technical Discussion 10 12-12-2015 08:25 PM
Clanking noise from left side. zoko230 Member Introductions 0 07-29-2015 01:07 AM
Bike made a "Bang" noise this morning while trying to start it SeraSera Technical Discussion 16 03-11-2014 06:19 PM
Gears clanking after 1st long trip? JJBulldog57 Technical Discussion 6 07-31-2010 05:27 AM
Clanking sound on bumps - Top End? SYKOMOM Technical Discussion 2 04-26-2007 01:38 PM
You may post new threads
You may post replies
