1 - 5 of 5 Posts
02 shadow spirit 750 lost all power except when i turn the key it sounds like its turning the starter motor even with the kill switch engaged any ideas?
Is the starter actually turning the engine or just sounds like that?
If it is, the solenoid may have stuck.
Check the wiring to the solenoid also look for burned areas.
All the power goes through that area of connection from the battery.
2003 Ace Deluxe
i recently had a similar issue and it turned out my battery was shot.
the solenoid will not work properly with out 12V and it looks like the solenoid and or the starter are the issue.
see my post
looks like i need a new starter solenoid for my 03' shadow ace delux 750"
be sure you have 12 + volts.
2003 VT1100C Spirit
"kill switch engaged" ??
Do you mean that this switch is in the run or not run position?
Are you pressing the start button when this happens? Or just turning the key and the engine turns over without touching, pressing or switching anything else?
1 - 5 of 5 Posts
