Ive been working on my 92 vt1100 doing a clean up paint and such, i had to replace the handle bars because they were bent so i threw on a stock set of sportster bars which has the master cylinders on an angle. The clutch worked fine when i drove it home but after being worked on for few weeks and the master cylinder dangling upside down for that time now i went to ride it and no clutch now. i pull the clutch handle in and it doesn't feel like anything then i put it in gear and it jumps and stalls out. also i took the bolts out of the middle engine side cover on the left until i realized it was an oil sealing cover so i put the bolts right back in it. So any ideas on what i did to cause it and what i need to do to fix it?
