1 - 4 of 4 Posts
Hello again everyone, so I found bushings online that were 3/4 OD and 5/8 ID the Harley Wheel my buddy gave me the bushings work so that problem is so far so good….. next problem I have is a 1983 Honda shadow has a cable with mount at the front wheel. how do I Install a speed sensor on the front wheel and keep my existing speedometer? is this possible? If so part numbers please thank you advance for the help, you guys rock!
Chopperdavemays
Tire Wheel Fuel tank Automotive tire Automotive lighting
'83 VT750C
You’re in the realm of the unknown now… Does it look like there is any way to adapt the stock speedo gearbox to fit your new wheel hub? Granted, it could be off anyway if it counts rpms rather than teeth…
1 - 4 of 4 Posts
