I am posting my third thread in hope to get in to the technical forum and get some help.
I recently bought a nice 1986 VT700 with only 1800 miles on it. The bike was sitting for several years so I removed the carb and cleaned it nicely. The main and slow jets are cleaned and nothings clogs them. Here are the list of other things I have replaced or done
1. Air, fuel, and oil filters.
2. Spark plugs
3. Float valves ( I made sure the floats heights (levels) are set to the manufacturer suggested 9 mm value.
4. Choke cable valve sets
5. Flushed Radiator, gas tank, and the reserve tank
Now the bike will barely run (at idle only) if the chokes are fully used. A little throttle will kill the engine. Do I have an air leak issue? Or should I check the fuel pump? Any help will be greatly appreciated.
Thanks,
-Marco
2. Spark plugs
Thanks,
-Marco
