For diagnostic purposes, while I was working on my '96 1100 ACE, I bypassed the fuel pump and filter and connected the tank directly to the line that feeds the two carbs. The bike ran fine, although,
- I was just idling and revving with no load,
- There was no filter inline. I had, however cleaned and derusted the tank before doing this.
I have read that folks have connected up their tanks this way permanently. It seemed to me that flow might get sluggish for the last few quarts of tank capacity, there's not much elevation of the bottom of the tank over the carb inlets. And, I'd want an inline fuel filter. TJ Brutal Customs is an advocate of this mod, but then, his motto is "
Ride Fast, Take Chances and DO FUN ****!!!" Can The Fuel Pump Be Removed From My Bike? - TJ Brutal Customs Support (shoptjbc.com)
Once I got the engine running reasonably well on my machine, I reconnected the loop down to the fuel pump and filter, and made sure everything in the system was working correctly.
The manual suggests a fuel flow test. If I remember correctly, with the fuel pump "relay" bypassed, and the carb feed line running into a collection jar, the system should be capable of delivering 800 ml / min to the carbs.
