do the fronts go back to working if you disconnect the new rear turn signals What turn signals did you install and how do you have them wired?
Thanks . Exactly what it was🤦♂️🤦♂️The front is working correctly, I'd bet you blew the turn signal fuse.
The switch kills the run light on the front for the blinking side for better contrast I believe is what you are seeing.
