On what bike, but like others said, not much to any room in there.I was wondering, has anyone put a 19T front sprocket on for a little extra top end speed?
Just be careful not to blow water past the shift seal into the crankcase. You could end up with a watered down crankcase. Those pressure sprayers can put water where you don't need it!This reminds me...
I need to check that front sprocket on my ACE
I ain`t gotta remove the shifter linkage to access mine![]()
I received a Christophers Christmas gift several years back and recently installed the Nearly new rear, to make it through "hard times"...
But as long as I got the cover off, I`ll put the nozzle of the pressure washer in there to clean the built up crud...
No, use WD-40, itll clean the gunk and not ruin anything behind it.This reminds me...
This!!Engine cleaner might ruin the o-rings on the chain, WD-40 wont.
