I thought I would move this thread here to get it off of the intro page. For a quick recap I have a charging problem. I replaced the battery, stator and rectifier a couple of weeks ago. I rode a few times not all that much and then last Monday it left me sitting with a dead battery. Today I removed the ground wire and scuffed it up with sand paper to make sure the ground was good and still no dice, reading 12.5-13 volts off the battery rather its off at idle or 5000 rpm. I checked for continuity at the connection for the stator and rectifier and had nothing on the stator side but good continuity on the rectifier side. This means I either got a bad stator or I have burned one up in just a few hundred miles. Should I be concerned about replacing the stator again? Is there anything that would make the stator burn out that quickly? Or should I just write it off as I got a bad stator replace it and move on? My fear is that I am going to replace the stator again and still have the same problem and I am just about out of dollars to solve this situation... Any feedback will be appreciated...
