1 - 6 of 6 Posts
Hi guys,
I need to buy a new battery for my 2003 Honda VT750CD. Any recommendations? It's easy enough to find a battery that fits but I'm curious if there are certain brands that are preferable.
R
1995 VT1100C2
I have had good results from a variety of brands including chinese knock offs. The one thing I did find is that AGM-type battery lasts a really long time and does not require as much storage charging (I no longer use a tender with it for the last 4 years)
Super Moderator
I like the Yuasa AGM batteries. Whatever brand you go with, get an AGM battery. They're less messy, and in my experience they last longer than wet cell batteries.
I gotta be different. I like the Lithium-Iron phosphate LiFePo4 batteries. Have a Shorai ( ShoraiPower.com ) in my Versys, ( 5 year pro-rated warranty,,,) was supposed to go in my Tourer, but the Versys died 1st and took the same one. (Tourer already had a MotoBat I had to buy while on a trip, and it's the t-shaped one or I'd have swapped them. Will get another Shorai when the others die. My 750 Ace has a Yuasa iirc. On any of them, Follow the initial fill and charging instructions to get the best results.
Super Moderator
Curious........ do Lithium-Iron phosphate batteries require a special charger?
Phil
Phil
A definite maybe... Think it depends on brand, Shorai has their special charger, but it also says a regular type can be used, but may not get 100% charge, or something like that. Their battery has a special charging port that allows their charger to charge each cell individually. Drawback is the port may not be accessible with it installed, there is an extension cord for the port that should work in most cases though.
And they are smaller, weigh about a third of the regular lead-acid batteries, and have more cranking power. means you can have a stash box place under the battery. And no acid to ruin the stash place.
1 - 6 of 6 Posts
