1 - 13 of 13 Posts
It would be easier and cheaper to convert it over to a choke like on the 750's. ChopperScott has done this to his 1100, so it's not my idea. His looks and works great, and you can adjust the tension on the cable, unlike the chokes on the left grip.
Brian
GrymLocke said:
think sounds like a good idea, so far i'm having trouble finding what I need.
Many Kawasaki KLR650 owners have used the stock Harley Sportster choke cable; the KLR has the same carburetor as the Sportster, so it’s an easy swap. Take a look at a Sportster to see if it will work for your bike.
I kinda like the Harley choke control on the left side of the motor; it’s one less thing to have on the bars.
Discussion Starter · #8 ·
navillustoo said:
Single carburetor choke cables won't work too well on a dual carb set-up. The 750 Spirits and ACEs both have dual carbs and use a similar if not identical enrichening valve as the 1100s use.
Brian
so does that mean I can use a 3 over ment for a 750 on my 1100 ACE? if they're like the throttle/brake I should be able to put that little steel end nut replacing the original? just a direct swap?
Does your 1100 ACE not have the choke control on the left side of the handlebars? The trick to get around a buying 3" longer cable is to convert to the choke control like on the 750's. They have a knob and bracket located on the left side of the engine between the cylinders.
As I mentioned earlier, ChopperScott would be glad to tell you what he used and how he did the conversion.
Discussion Starter · #10 ·
I'd like to see if the brackets/knob/cable/etc would bolt onto the 1100...(possibly a swap over?) do you have any pics?
Discussion Starter · #13 ·
1 - 13 of 13 Posts
