i have an 84 vt500c shadow
after weeks of trying to figure out why the headlight wouldnt work i finally figured out the fuse panel itself was bad.
i tried to take it apart and soder it back but it just wouldnt hold the fuse tightly and the headlight would flicker or go out at the slightest bump.
so after looking and looking i finally found one. it was suppose to be off an 84 vt500c. once it arrived i could see there were some minor differences but the plug ends were the same and the actual fuse centers were the same. ( i beleive after much searching the one i got is off an 83 vt500c )
so i went ahead and started to install it. upon taking the old / broken one out there was an black with yellow stripped wire coming out of it, this wire was not on the one i purchased. it pulled out of the fuse block when i was disassembling the fuse panel. ( which might be why the brake lights didnt work correctly )
so heres my issue i could use some electrical guru knowledge on.
the black w/ yellow strip wire seems to operate the turn signals and brake lights please correct me if im wrong here im a noob at elctrical but did try to figure this out myself.
the wire comes from out of the wiring harness of the bike and
according to the break down book it does control both the turn and brake lights
with what i have now the rear lights stay on, i believe they are the parking lights and i have no brake lights at all, and my turn signals do not work at all.
how can i make this work?
can i route this wire somehow to make my turn/brake lights work is what im asking, sorry if its not clear but id rather give to much info then not enough.
