For the record..lol I never said that syncing will make it run leaner, allthough it does look like i was illudeing to that now that I read it again...lol. So i will explain what I meant by that.
Imo, If someone is having a hard time getting the bike to run right after a pod mod and an agressive rejet, I would sync the carbs because with that much air and fuel being dumped into the carbs the last thing you wanna chase is a lazy opening throttle plate. I meant it more of a dial in then a help/solution for a lean condition. Which it most certainly does not solve.
So I appologize for that guys. With that said, Leathel is absolutly correct. And to add to that, if you were that rich as Leathel decribed you would have gas comming out of the pipes and/or your plugs would be soaked in fuel.
I'm stayin with my first prognossis becuase if it didn't come with an airbox and your jetting it with those oversized airfilters, it will most definately act like it is.
But AGAIN, Leathel makes a good point. If the airbox was missing, who's to say that the P/O wasn't chasing down a fuel issue. So maybe its as Leathel says and you have float, needle valve issues too.
Its really hard to fixshit on the internet..lol.
